Originally posted by Pinpoint
View Post
Er, looks like your friend may have "Ham Fist Syndrome", or HFS.
Did he leave residual flux on the board? If it was no-clean flux, that is not a big problem. But rosin flux needs to be removed. Scrub with a soft brush and some 91% alcohol, then rinse the board with alcohol. If the flux has been on the board for more than a few hours you'll probably need to first let it soak for a while. Repeat as often as necessary. Compressed air really comes in handy for cleaning under components but that's a luxury.
Try not to get alcohol in that other potentiometer
That white box is a 33nF (.033uF) +/-10% "film" capacitor with 100V rating. I believe it's made with either Mylar, polyester, or metalized polyester - either one would be fine. You don't absolutely need the 100V rating, I think 63V or even 50V should work. I can't tell you to replace it but anywhere I ever worked had zero tolerance for solder iron dings on capacitors.
