Today I opened first time this detector and
created that modification:
The Blisstool uses an internal lithium-ion pack
and if this is empty (after perhaps 45-90 hours)
you need to charge it again because there is no
way to use a reserve-pack.
But it is simple to use the CHARGE connector
for such second battery or accu-pack.
Warning: You will lose the warranty if you remove
the epoxy that covers the both screws on the cover.
And if you forget to remove the wire-bridge while
using an external battery the li-ion pack could
draw too much charging-power within a very
short time and eventually even may explode.
So try this mod at home
only if you know what
you are doing and if you have enough electronical
experience!
Usually the internal accu-pack lasts long enough so
it works even after 1-2 weeks incl. 8 hours per day and
can recharged after this period but for special occasions
you may want or need the safety of a reserve-pack and
then this mod is for you!
experience!
