GROUND CONTROL PI CIRCUIT
  • #61
    t^-1 works in ideal world. It is generally not a quality of ground as much as quality of equipment that spoils the t^-1 relationship, but it is there, and one should provide for slight variations. A big contribution to the mismatch is a duration of Tx charging period, or better say the lack of it. The ground response skews from a perfect t^-1 after the same amount of time as the charging period.
    • #62
      The mismatch is
      Some ideal examples of the regression technique (times in us, normalized to the first sample):
      Target signal : with tau = 4us.
      Ground signal with delta t (on-period) = 50us:
      Regression to 1/t of 10 samples:
      1. ground signal:
      Code:
      ---- 1/t - 1/(t + T) --
      1    1
      2    0.490384615384615
      3    0.320754716981132
      4    0.236111111111111
      5    0.185454545454545
      6    0.151785714285714
      7    0.12781954887218
      8    0.109913793103448
      9    0.096045197740113
      Best fit: 0.98 / t; rss error: 0.0019
      2. target signal:
      Code:
      ---- e^t/tau--
      1    1
      2    0.778800783071405
      3    0.606530659712633
      4    0.472366552741015
      5    0.367879441171442
      6    0.28650479686019
      7    0.22313016014843
      8    0.173773943450445
      9    0.135335283236613
      Best fit: 1.23 / t; rss error: 0.17
      3. target + ground signal:
      Code:
      ---- e^t/tau + 1/t - 1/(t + T) --
      1    1
      2    0.618067447748263
      3    0.447268712649278
      4    0.340702210114235
      5    0.266214676086582
      6    0.211426316872256
      7    0.170013885270402
      8    0.138184901955875
      9    0.113439054125622
      Best fit: 1.09 / t; rss error: 0.028
      Conclusion:
      error of pure target is 2 x orders of magnitude the error of pure ground.
      error of ground + target (when signals are of the same order) is 1 x order of magnitude the error of pure ground.
      I believe there's a basis for ground balance here.
      • #63
        Good information, but how do we convert these mathematical formulas into practical working circuits ?
        • #64
          The cirtuit should in principle remain the same, it's just how you process the samples.
          • #65
            Conclusion:
            That's the general idea. However, the ground will almost certainly assume a bit different exponent which you may compensate. You can't simply dismiss the ground because there is literally 2 orders of magnitude more of it than a target.
            • #66
              A typical implementation is an H-bridge:
              http://en.wikipedia.org/wiki/H_bridge
              There is an Hbridge driver chip L9110 and another one that are cheap anc commonly found on simple ebay motor controllers for arduinl I think this might make a good Hbridge driver (even for the hbridge mod to the TGS
              • #67
                Thanks for the heads up on the L9110
                • #68
                  Thanks a lot for this wonderful device
                  File Programming
                  • #69
                    OK - now I've got it.
                    Your equation is not as I assumed. In fact, it is:
                    x = A1(S1) + A3(S3) - A2(S2)
                    where A2 = A1 + A3
                    In your case, you're using different sample pulse widths to achieve / adjust the gain, but the result is the same.
                    As a test, with TS1 = 10 and TS2 = 2, the gb gain (A2) needs to be 5 in order to cancel the ground signal, so we have:
                    TS1 = 10
                    TS2 = 2
                    EF = 2
                    S1 = 12
                    S2 = 4
                    S3 = 2
                    A1 = 1
                    A2 = 5
                    A3 = ?
                    Let's calculate the required value of A3 (EF gain) to set x to zero (ground balanced).
                    A3 = (x - A1(S1) + A2(S2)) / S3
                    A3 = (0 - 1(12) + 5(4)) / 2
                    A3 = (-12 + 20) / 2 = 4
                    If you try various values for EF, the value for x is always zero, and the detector remains ground balanced.
                    So the big question is - why does this technique work in the same way as equation 2?
                    Here's the answer:
                    Starting with equation 1 : x = A1(S1) + A3(S3) - A2(S2)
                    Since A2 = A1 + A3, then: A3 = A2 - A1, and substituting for A3 gives:
                    x = A1(S1) + (A2 - A1)(S3) - A2(S2)
                    x = A1(S1) + A2(S3) - A1(S3) - A2(S2)
                    and now I bet you can see what's coming ...
                    x = A1(S1 - S3) - A2(S2 - S3) ........................ Viola! Eq.2
                    So, x = A1(S1) + A3(S3) - A2(S2) = A1(S1 - S3) - A2(S2 - S3)
                    i.e. Eq.1 = Eq.2
                    How did you come up with this alternative scheme without working the numbers?
                    Hello George
                    do you remember back when you did all the maths in reply #27 for Mickstv GEB solution ?, which intergrator configuration does the maths apply to, was it this one attached , with the signal straight out of the preamp ?
                    Thanks.
                    • #70
                      Hi 6666,
                      I'd use an inverting stage after the preamp then use a single ended integrator stage....
                      • #71
                        Hello George
                        Thanks.
                        I'm not sure it really matters which integrator configuration is used. The one you posted is similar to the Hammerhead, which I believe will work by adjusting pulse widths to change the gain.
                        • #72
                          Originally posted by mickstv View Post
                          Hi 6666,
                          G'day Mick, good to hear from you, hows things ?
                          • #73
                            Hi George, I spent plenty of time testing both options, but the best method for GB and EF cancel is to use the single ended integrator method. It works better for wide samples.
                            • #74
                              Hi Bruce, yeah going good, spending time out detecting yellow stuff...
                              • #75
                                Thanks George, maths is not my strong point in my ageing years, was trying to match the circuit to the maths.
