Fascinating specs on the original CHANCE planar basket coil. If 36" of RG62u cable was used with it, the added capacitance would only be about 40.5 pf. I presume your coil is wound with enameled wire. When I look at all the parallel enameled wires in the original coil design it appears that there should be a lot of wire to wire capacitance on each face of the coil. The 4 mm thickness of the plexiglass does minimize capacitance between wires on opposite faces of the coil. Seeing all those close spaced 22 awg enameled wires it is also hard to believe the original coil has only 30 pf of capacitance even though that is how it calculates. Makes me wonder what dynamics are at work here.
I have a number of coils that I will run SRF on tonight, including the original design from CHANCE wound with 26 ga teflon insulated wire.
Dan
Dan
