Discrimination doing exactly the same or similar as gs 4 except that very calm and stable with modifications components obtained a better range than gs 4 ,diskriminacion take over as rejection ground and rejection iron as again more as that works gs 4 gs 5 or Tdi ...
Serbian pi Gold-Skan
I did in the past and the GS4 works great iron discrimination.
I had to make my own design Lay Out for GS4 so that he can get more performance.
The GS6 is deep in Orbit videos, but there is an error on your PCB or the scheme and I am not able to give with.
If there alguen you can find the error, I would be willing to start again because the GS6 deserves another chance.
About 1 month after I finished and I can say this detector is a detector that deserves all the work, the problems discovered by me are used in PCB Orbit another version of PCB, to function properly managed carefully made PCB photo of him in those two 1nF capacitors from 4093 and used 2N3904 anything, pin 2 and 3 to reverse the LM385. Thanks Orbit
GS6 Hold Auto mode works perfectly well but discrimination makes detection range is small and is very stable, the way All metals when they hand coil or close to the ground it remains stuck with the maximum detection signal to press the reset button, no metal It has varied around the detection coil. I said it very well shielded assembly. I tried with another type of coil but identical in terminal 6 at NE5534 have varied high-00.60V to 00.0V.
After many hours of work, I designed Lay Out the GS-6 version ORBIT.
The scheme had some errors which are corrected. There are two versions Lay Out, the original errors, and another without errors. I ask Orbit please check if everything is correct. I also added the power supply in version Lay Out.
A greeting.Attached Files
