Serbian pi Gold-Skan
  • Hi ! what is the correct value of V+ ?
    thank you
    • Have : -5v and +5v ,and two gnd first part of the scheme gnd is negative in the second part of the scheme is positive gnd,very simple I do not understand so much the problems, circuits are supplied with 10 volts , power 12v ,gnd - negative and gnd positive .Salute !
      • with what I can replace the germanium diode oa85?
        • Put the BAT85 and do not worry !
          • The correct value for c28 is 220pf ?
            220uf ?
            • ok i'll try to figure it out thanks
              • Hi all
                Where is thé value for inductor(L) 100mh or 100uh.?
                Can i use ceramic capacitor for 100N value.?
                • 100uH
                  • GOOD
                    • My gs6 works !
                      • Originally posted by asolone View Post
                        My gs6 works !
                        Congratulation
                          • there is an error on the basis of the times!!!!!
                            r20 can not be value from 51k....must have a greater value ........????
                            • Yes 240k ! reduce slightly the frequency C-27 =22nf =68nf Increase little pulse width etc !
                              • hi orbit
                                it is possible to publish the correct lists of components
                                thank you
