Hey guys
Today I'm going to introduce a very powerful metal detectors.
This metal detector is very simple and powerful .
And I think it is the best system that has ever been given for free to the public.
It is appropriate here to thank the designer (Mr. Hamid from iran).
Then I put the necessary files to build the metal detector and give explanations about it
The designer of this great system, to avoid unwanted effects caused by the parts and hardware as well as to reduce the size of the system and making it easy for most users, as well as those who have little knowledge of electronics, small parts used .Instead, with an accurate and professional programming, all features are included in the scheme and applied digital.
The facilities that puts the plan the rows of systematic and powerful global celebrity and gives many special features to the operator.
Features such as:
Sensitivity
Frequency regulation
Adjustable pulse width
delay
Contrast adjustment
Adjustable back light
Sound setting
Change the type of sound
iron reject
Target ID (The numerical separation of various metals)
Automatic Balance
Debug
Integ.W ( Set the interval integrator)
Adapting to the ground(Self Adjusting Threshold)
Set the speed sensing
And ...
And other features that I still have not seen any examples published.
Of course, I've already made a lot of systems, but none compare to the system and I recommend you try to make it yourself to see with your own eyes, the power and possibilities of this system.
Of course, to prevent abuse and fraud by metal detector vendors, using of the system is limited to 300 times by Mr. Hamid
However, this limitation is not harmful to the public, but to prevent fraud and abuse by individuals is essential.
At the end of 300 times, a programming can be re-used again and again to set up the system.
Features such as:
Sensitivity
delay
Contrast adjustment
Sound setting
iron reject
Automatic Balance
Debug
And ...
