  • help for coil 1x1 what thick wire cables are spindle self-inducing
    • 10 round with 1m cable with a thick cover
      • Originally posted by basellafe View Post
        thank you my friend
        • Hi do you know what is the use of A: 300 B:700 C: 800 for Ohm or uH is for the coil ?
          • Hi i have made new coil and the numbers is A: 295 B: 700 C:799 Delay: 22 ( +8 ) is good ?is any alse i can do?
            • Good numbers but the manual delay should be as the size of coil for a big coil use a high delay like 40 and small coil use around 20
              • Originally posted by Kostasp View Post
                How much is the inductance?
                • hi all! this is a Felezjoo clone?
                  https://newhobby.eu/en/home/28-metal...induction.html
                  if no, is a good detector kit?
                  • Could be clone PI
                    • Hi basellafe you say that if my coil is 20 cm that i must have 20 delay or if is 40cm then i must have 40 delay ? thanks and what is the first 22 and what is the second ( +8 )
                      Altair : inductance is 400.
                      • felezjoo pi
                        with what associated ( A:300 B:700 C:800 ) is any of this for the Ohm of coil or uH or volt ?
                          22that is the Automatic delay for coil +8 is the manual delay that you should put for stabelity for big coil like 60 must be manual delay from 30 to 40 as stable you find
                          • thanks basellafe
                            • it works with a 12v battery or an 18v battery is needed?
                              • 18
