  • Originally posted by etwert View Post
    Dear pigeon, I did not doubt your correctness. The problem just exists.
    Sincerely, etwert
    I believe 7805 is reverse
    • Hi Dear Amin , could you upload it here? Thx for your kind interest.
      • Hi friends can ennyone here get nother hex file for this felezjoo. Because felezjoo of balgharia has hex file allergy
        • I see felezjoo of balgharia works fine with Differed hex file
          • V3.20 ,unlimited ? no counter?Who can share it?
            • unlimited and no counter for all
              FelezJoo_PI_v3_35 (no counter).hex
              • Thanks...
                • Felezjoo PI variant with all major components on-board (LCD, joystick board).https://easyeda.com/MDfanatic/deepi-smd-metal-detector
                  • I was going to present it at some point. It's still a work in progress.
                    At the moment I will make the project private and I will release the final SMD version at the forum.
                    For the rest of the guys that copied the project, please use it at your own discretion only.
                    • For those who copied the project, this is the joystick board that was meant to be used on-board: LINK
                      You will have to desolder the last 2 pins labeled SET and RST because they are not being used on the layout.
                      In the final version the joystick key will be on-board without the need to buy the external joystick module.
                      • does anyone get the gerber file?
                        • This is the version that's most often found on the net:
                          https://drive.google.com/file/d/1D52...VqCKBmBj9/view
                          • Comment
ID:	358932pcb 83x48 m
                              • Originally posted by star View Post
                                [ATTACH]54182[/ATTACH]pcb 83x48 m
                                Where is the pcb file?
