    Try several parallel resistors that will get you below 10 ohms
    7ohm A115 B332 C481
    5ohm A117 B339 C485
    • Hello
      try lf357j or metalic lf357h from Motorola to get near 300 700 800 A B C and replacement with 470-570k for 1M near 357
      • i replace the 1m resistor with 470k, values are A241 B578 C713, autodelay 26 (with 1m are 24)
        I think I still improve the values ​​by finding the right value of the resistance
        if I go down under 470k resistor risk of burning something?
        • Originally posted by useus View Post
          I have changed the 100 ohm resistor by 280 ohm.
          some person change the IRF840 by IRF740
          • Originally posted by gandolfi View Post
            did you even change 1mohm resistance with a 470k resistor?
            • The whole problem is of 357 ... Find the correct 357 or 356 !or 1m with 470k or 330k....
                A262 B658 C775
                delay 22
                thanks!
                now I try 300k and the values ​​should become almost perfect
                • do you think this is original?
                  https://www.ebay.it/itm/Lot-x2-ci-LF...UAAOSwy0JaHR06
                    It's hard to know if it's original I bought 20 pieces from Serbia all were defective I bought from Bulgaria and everything was right ..
                      you're telling me that I have to spend 100 € to find one right... LOL
                      • I put resistance 220k, now the values ​​are quite good! anyway I'll be looking for an lf357h to make a comparison
                        A294 B727 C816
                        one last help, 7812 is really hot, can it be due to the fact that I'm feeding the metal detector with an 18v 1A power supply?
                          Yes. The Heat (Watts) of linear regulators = Voltage Drop times current. Higher Voltage input really drops the efficiency due to excess Voltage producing Heat.
                          Also, these older 78xx regulators are rated for 1Amp only if the Heat size size is infinite.
                            thanks do you recommend 3x 6v in serie batteries (4,5ah) or single 12v (7ah) battery with step-up converter?
                              no i keep 1M
                              - Is it best change ? Resistor of 100ohm by 280ohm or 1M by 220k ?
                              - can we change 7812 by a better regulator ?
                              - how we can verify true or false LF357 ?
                              - is there difference in performance between 14.8v (4x18650) and 18V (5x18650) ?
                              thanks
                                no i keep 1M
                                thanks
                                -I'll try 280ohm (if I find it or I can do it) and I'll do the comparison
                                -7812 alternative i don't kown... lm338?
                                - apparently it is not possible
