this pcb is not the oregenal one try to acheve deffrence with the oregenal one and test lines from a short secret if not the problem will be from prgraming or fuses you should hear a peeep when turn on
Originally posted by chuubaba View PostTHE PROBLEM WITH MY CIRCUIT IS THAT THE VOLTAGE AT HIGHLIGHTED POINTS WAS GOOD PRIOR TO INSTALLATION OF ATMEGA AND LCD BUT WENT DEFICIENT AFTER ATTACHMENT. TRIED REMOVING LCD BUT STILL NO RELIEF. I DOUBT PROBLEM WITH LCD AND SUSPECT ATMEGA PROGRAMING AS I HAVE CHANGED THE IC THREE TIMES WITH SAME RESULT.
Originally posted by gandolfi View PostMine is the original PCB.
- Iran kit is it better ?
- Iran kit add an IC with a hex to program no ?
- Is it the original hex on atmega ?
Basellafe this video does not show how ATMEGA328P is connected. I have tried this by connecting the ATMEGA328P using my method of connection but only hex files are installed but the fuses fail. Please show how to connect the ATMEGA328P to achieve the desired result.Originally posted by basellafe View Post
For setting the fuses for atmega328p with arduino as ISP you have 3 ways using arduino and modify the setting at programmer directory or us avrdude directly with command line or use universal avrdude GUI and put the programmer as arduinoisp and you need to read about avrdude command line he is the most used programmer I didn't use all this thing before because I have avr dragon and it work with atmel studio there is a ton of topics about t what you are looking for just use avrdude and arduinoisp
