What are the damping resistor values on the RX and TX coils of your DD coil?
The current turn off Time Constant is based on the coil inductance divided by the damping resistor value. Eric Foster reported, many years ago, that the turn off time constant should be 5 times faster than the TC of the target you are seeking to fully stimulate it.
I took a different approach to KingJL by using a high voltage source (150V) to force the current up to 998mA in 10us, before switching to a low voltage source (6V), which continues to charge the coil for another 40us. Therefore, after 50us the total current reaches 1.07A. The current waveform is a very good match for the scope picture posted by Eric. Also, the TX pulses sit symmetrically on the 10V reference voltage. Using this method you don't need to limit the coil current to 1A, as the selected voltages and timings do that for you. Perhaps that's why the Vallon is so fussy about the coil parameters.
If you're familiar with SPICE, then it should be pretty obvious how this works.
My experience with a DD balanced coil and MiniPulsePlus is no salt noise at 6u delay (the earliest I could get).
I'm sure you've already checked this ..... but I have to ask:
Is your coil actually capable of being sampled at 6us, and it's not just sampling while the opamp is still saturated?
Any chance of posting a scope picture showing the preamp output versus main sample pulse?
I didn't check the amplifier state, but since it works I guess the preamp is not saturated. The peak of transient at the Rx coil is about 3V, decaying into the mV range at 6us. It is a very well balanced DD coil. My guess is it balances out the salt water signal just as it does with the ground.
Give me a week or so before I can find the time to get the scope pics.
The coil wire is AWG23 enamelled copper. I would not have used solid wire because of cross sectional eddy currents resulting in a 'slow' coil. Nonetheless it works.
Using the voltage MT3608 converter board now in a little screened box, I can now dispense with the 10AA batteries in my viscosity meter. The reason I used 10 was to get enough overhead to regulate at 12V for the TX so that the signal from the soil would not lessen as the battery voltage diminished. I could of course use a current regulator instead for the TX stage. This instrument is used both in the field and the laboratory with different sensors. In the lab. a wall plug 15V power supply is used instead of batteries.
With this converter I can run for about 8 hours on two 2400mAh cells in parallel and it is much more convenient to change just two cells instead of 10. Another advantage is that one version of this converter board has a mini USB connector so that it can powered from a laptop, or other computer, with which the meter is often used.
I can see that I shall be using this type of power supply for other detector projects.
My real 18650 2600maH batteries arrived this week, they weigh 49 grams,
did a charge and discharge test
Discharged at 500mA over 5 hours, and recorded around 2525 milliamp hours capacity
lowest discharge voltage was 3.22 volts, before safety timer stopped test, so happy with that.
On the off-topic subject of Lithium batteries/cells, I was just this week looking into using AA (14500) Lithium rechargeables for a project (bicycle light), and it's really hard to find any cells that are genuine quality ones. eBay is just one continuous list of unbranded or xxxxFire junk with vastly overstated capacities. The best cells in this size are 850 mAh (Sanyo / Panasonic) , but there's no shortage of Oriental 1200 mAh etc stuff to trap the unwary.
So it's not just confined to 18650 size cells. Quite a number of AA Lithiums have built-in protection circuitry, which comes at a price - the capacity is reduced, and the cost is much higher. It seems that a common use for them is in high-power LED torches.
Funny stuff: Whilst doing my research, I came across a forum post, stating that these xxxxFire cells should be re-named:
"Guaranteed-to-start-a-Fire".
Sounds right to me.
Hi George,
I finally got the time to run the scope.
Blue line: main sample pulse (TP7)
Yellow line: preamp output (TP3)
I'm sampling at 5.5us just as the preamp is recovering from saturation. Tx coil is slightly underdamped.
I've been adjusting R1 and the minumum delay for the best sensitivity to a test gold chain.
It has been noted in the past that using a slightly under-damped response can lead to increased sensitivity to low conductivity targets, and your results seem to indicate that this is true. Have you noticed any undesirable side-effects from this setup?
There's a background growl in salty wet sand, but objects still cause a distinct beep.
Sensitivity is so increased that it can detect an axial resistor with its leads cut short. I tried a 1cmx1cm piece of aluminium foil and it was detectable at 2 - 3 cm.
