Originally posted by Ferric Toes
Vallon VMH3CS Mine Detector
Standard headphones for the VMH3CS
I managed to put together a small plug in unit which enables the Vallon to be used with normal, inexpensive moving coil headphones. It also appears to work fine with an FM wireless module and FM headphones. The angle of the FM transmitter can be altered to give the best reception to the phones. I wonder how this wireless method will work on a wet beach where basically you have a huge ground plane which may affect the propagation from such small antennas.
Eric.
Based on Eric's earlier post. I used a matching transformer and some pvc pipe fittings to make an extension to 1/4in. adapter. It keeps the headphone cable out of the way behind the armrest. The pipe fittings are 3/4" and the pipe is 3/4" schd20 thin wall. The transformer is unmarked, but I believe it is about 600ohm : 8ohm. I have tested it with my "Nugget Buster" headphones and some homemade piezos. Very loud.
I was reading about Vallon detectors on another forum. Found this interesting: "As a professional user of many types of detection equipment, down to the simple MD, I can assure you a Vallon will easily detect the items as you described. My personal detector is the VMC1 with modifications perform by me. Vallon will NOT modify detectors from their intended design. So don't even ask them"......I wonder what the modifications were?!!!!! I have sent the writer a msg, but given the post was quite old, I am not confident of a reply
Originally posted by Altra View PostBased on Eric's earlier post. I used a matching transformer and some pvc pipe fittings to make an extension to 1/4in. adapter. It keeps the headphone cable out of the way behind the armrest. The pipe fittings are 3/4" and the pipe is 3/4" schd20 thin wall. The transformer is unmarked, but I believe it is about 600ohm : 8ohm. I have tested it with my "Nugget Buster" headphones and some homemade piezos. Very loud.
[ATTACH]39189[/ATTACH]
[ATTACH]39187[/ATTACH]
[ATTACH]39190[/ATTACH]
[ATTACH]39188[/ATTACH]
Eric re your FM cordless TX, great invention, I have used a digital tuned FM TX similar to the one in your picture, I used it on my Ace 250, worked very well, had a small problem with over driving the audio , just needed a small inline pot to reduce audio, and then worked perfect, used a pocket FM rx to listen to signal.
Originally posted by kingswood View PostI was reading about Vallon detectors on another forum. Found this interesting: "As a professional user of many types of detection equipment, down to the simple MD, I can assure you a Vallon will easily detect the items as you described. My personal detector is the VMC1 with modifications perform by me. Vallon will NOT modify detectors from their intended design. So don't even ask them"......I wonder what the modifications were?!!!!! I have sent the writer a msg, but given the post was quite old, I am not confident of a reply
Originally posted by garyq View PostI read also on another forum that for deeper detection, the better Vallon detector is the VMH3CS with the 60cm diameter UXO search head, which can find large projectiles down to ~4ft, so relic target depth would be dependent on how much metal they have.
I read a lot of test reports and the Vallon with the 30cm and 60cm search heads did very well on half a BLU-26 bomblet, which as far as I can work out has a weight of 220 grams of metal.
All quite promising!....the 30cm coil should detected a 2 kilo nugget quite deep!....Now just have to walk over the top of one ha ha
Originally posted by TH'r View PostHello Eric; Tried this experiment with the following results. When I held "C" down in volume mode I got LED's 6789 followed by 2 & 11 (not 12) on the less sensitive to EMI Vallon. On the more sensitive to EMI one I saw 6789 followed by 9 & 13 (not 12?). I changed the channel to #2 but there was no improvement in the EMI situation.
Originally posted by TH'r View PostMore experimentation. How many channels do these Vallon's have? Mine seem to have four banks of 10 channels each with the numbers 11,12,13,14, being the group or bank numbers. After considerable trial and error I found Ch. 5 of Bank 11 made my noisy Vallon completely quiet.. The manual mentions 40 channels and I wondered how they came to that number. I will have to set one up on a frequency counter to see the range of the TX prf. over the 40 channels.
Eric.
