Vallon VMH3CS Mine Detector
  • Don't give up
    If your coil shaft and connector is difficult to align in the keyway in the upper shaft, don't give up. A little force may be necessary, but it will go in eventually. A push from a passing tank may help, but in this case it broke off the outer collar.
    Eric.
    • Does this detector have discrimination?
      • I just built the rat phone , very nice audio and now i understand the name "rat" it sound like a rat , just a small error in the schematic : connect pin 3 and 4 and it work
        • Alexismex:
          Can you tell me where you found the 600 ohm Kobitone speakers used in the Rat phones? Have been looking for years
          now. The term Rat phone came from the 6" tail coming out of the phone that the phone cable plugged into. The cable was replaceable
          since that is the part that usually fails. With it unplugged the black phone with the tail resembled a rat. Let me know about those speakers please.
          • Stefan-s :
            The VALLON VMH3CS has no discrimination as you are questioning. There are those here that say they hear a difference in tones, but for me only depth of the target and not target type gives a distinct difference.
            Carolina
            • Because i do not have a 6oo r, i used 64 Ohms headphone and it work , when you adjust your pulse detector at the threshold it make a sort a wooble (low fcy) and a high fcy also (the potenciometer adjust the pich) , and with the continuous mouvement of the threshold the sound it like a minelab sound....a squeaking, hissing, and chattering sound, like a rat...giving a sort of more sensibility in the search
              • So if i understand you correct the detector give depth indication?
                Originally posted by Carolina View Post
                Stefan-s :
                The VALLON VMH3CS has no discrimination as you are questioning. There are those here that say they hear a difference in tones, t
                Carolina
                • Stefan-s:
                  The VMH3CS has no visual screen to indicate depth. Only the audio ( for me ) indicates depth from a change in pitch. You
                  can tell ( with practice ) the difference from large objects such as cell phones or cans and large iron verses coins and rings by their
                  shape. Also almost always a shallow object will hit twice or with a double audio response.
                  • Alexismex:
                    Are you saying you have a threshold tone now with the VMH3CS with these phones? My detector is a silent search
                    with audio response only when chatter because of sensitivity setting or a target response. Maybe I am deaf as the dickens.
                    Thomas
                    • Originally posted by Carolina View Post
                      Stefan-s:
                      thanks
                      • Carolina, no it is not the vallon, it is a general pulse induction .
                        • 0.6g round lead shot at 3 inches with standard coil. Made just a little squeak.
                          The more I use the Vallon, the more I am beginning to like the lack of threshold. I listen for little signals and if they can be replicated, I dig them
                          Some of the lead targets have been just little noises...but a signal all the same.
                          • Originally posted by kingswood View Post
                            Used a lead shot(BB split shot, fishing wt. pinched closed) to try with the detector I'm making. Charted some target time constants. Two split shot from different packages, 4 grain gold nugget, 1x1in aluminum kitchen foil and 1.5x1.5in aluminum kitchen foil. Reply #159 Eric could detect a 1.5x1.5in aluminum foil but not 1x1in aluminum foil. The time constant for the 1x1in aluminum foil and the BB split shot are close. I was thinking he couldn't detect the 1x1in aluminum foil because of the short time constant. Could you try a piece of aluminum foil 1x1in? I used Reynolds wrap regular strength not heavy duty. I got a little difference between the two split shot and foil thickness could be different. Wondering if there are reasons the split shot could be detected and not the 1x1in foil.
                              Interesting! I did try 1x1 inch foil ages ago and couldnt detect it...maybe its because the lead shot is round so is more dense??
                                Thanks, might be my error. Looked up shot size and a BB was .55g close to what you had(.6g) so that is what I tested. Just looked up BB split shot, .4g. I'll try to get a lead ball close to .6g and try again.
