Manta Metal Detector
  • #31
    Not at all he realized detection depth Manta detectors !?Goldscan 5C has a similar depth as Goldscan 4 or TDI !
    This is impossible because there is no detector aquamanta available to the public now.
    The goldscan 5C issue 4 and 2 are similar. (28 cm on palladium ring 3grs in black wet sand)
    The TDI pulsescan version only (high curent pulse not tdi sl) is below golsdscan 5c issue 2 and 4 (reference board) (22 cm on palladium ring 3grs in black wet sand)
    The goldscan 4 is significantly below the other. (20 cm on palladium ring 3grs in black wet sand)
    I did the retro engineering of all these detectors, so I speak with experience. This represents 15,000 hours of development over the last 10 years .... It is a true passion
    • #32
      what depth can you get on a US nickel ?????
      • #33
        [QUOTE = nickel_n؛ 217606]
        3،000.00 EUR
        4،657.52 AUD
        دولار استرالي
        1 يورو = 1.55251 AUD
        1 AUD = 0.644120 EUR
        ومما يؤسف له في هذا السعر سيكون بعيدا عن متناول بلدي
        • #34
          Metal enclosure is good for emi but no good for capacitance between mosfet / ground PCB / ground enclosure and metal heatsink.
          I recommend using a metal box and use a ceramic sink for the capacitance ! You'll see all your problems disappear! heat dissipation, emi, capacitance etc ...
          Hi Alexandre
          the quote above is from the Vallon thread
          are these ceramic heat sinks any good
          http://www.ebay.com.au/itm/10pcs-TO-...MAAOSwMmBVuE7W
          • #35
            Not isolators, but heat sinks, I think.
            • #36
              Thanks Alexandr ! I also I adore detectors Eric Foster !
              • #37
                Hi Alexandre
                These are isolators, not heat sinks.
                Heatsinks are made of Aluminum Nitride like attached file
                • #38
                  17 Pouces on US nickel with slow sat speed (12 pouces coil at 6us delay)
                  15.5 Pouces on US nickel with fast sat speed (12 pouces coil at 6us delay)
                  13 Pouces on square foil aluminium 1" (medium sat speed, 12 pouces coil at 6us delay)
                  16 pouces on square foil aluminium 1.5" (medium sat speed, 12 pouces coil at 6us delay)
                  Sorry for being late I had to find the money US
                  I would make a video later...
                  What are the records currently on the beach for this money at home?
                  • #39
                    Thanks for the results with the US nickle...with my home made detector with a delay of around 10 uS i can get a whisper on a US nickel at about 18" in air...maybe more in wet sand....and on a 9ct gold wedding band ring about 20" whisper...will look forward to see your video.
                    • #40
                      Thanks for information, the results are on wet sand for me, in air, I have a result most important but not real, ordinarily the small sound disappear on the beach because too ground effect near water and wet sand....
                      In France we have no 9ct, we had 18ct and 22ct (but rare), It is obvious that the 18k target is much harder to take than 9ct, we can not achieve depth of 20 "on the big rings and in some wet sand conditions (harsh downhole)
                      • #41
                        Je vis en Europe je suis intéressé détection à 1 euro 10 cents 20 cents et ainsi de suite qui ne serait pas chassé argent américain, et ai nulle part je lis qui est la dimension de bobines ?!
                        • #42
                          He said 12 inch coil #38
                          • #43
                            • #44
                              I live in Europe I am interested detection to 1 euro 10 cents 20 cents and so on would not be expelled American money, and nowhere have I read which is the size of coils?
                              Ok 6666 thank you !
                              • #45
                                whats the total current draw of your manta metal detector ???
