Why don't you just post the circuits and procedures here? Why make it so long, you've never seen a circuit diagram, you've never seen a 3, you've never seen a 4, why not make a Felezjoopi, which is hundreds of times better than this toy
PICKINI V4 - an easy to build, self adjusting PI detector
IAM using this pcb but sensitivity decreases why. https://www11.0zz0.com/2023/10/01/13/864822868.jpg
What do you mean with "sensitivity decreases" ?
Was the sensitivity OK and has it dropped ?
Has the detector worked OK ? or is this the first time you test it ?
Can you adjust the sensitivity potmeter between 0-5V ?
Can you show a picture of your actual board ( front and back ) ? The picture you show is the one from my website.
Can you also check your coil : measure it with an ohm meter ?
Are you getting the startup sound and after that the idle sound ? Or the coil error sound ?
This is the correct link to the coil error sound:
http://www.willaert.world/MD/pickini...technical.html
Hi friend ihave detect sound but after that sensivity decreased. . This may image. Pcb
https://www8.0zz0.com/2023/10/02/18/123883535.jpg
https://www8.0zz0.com/2023/10/02/18/521168270.jpg
https://www8.0zz0.com/2023/10/02/18/656630694.jpg
