something wrong with LT1054. The positive and negative values should be nearly the same. You have difference 1V what is to much difference. Check capacitors polarity. Near LT1054 one of them should be placed as "reversed"
I use common resistor (not POT) 1k with my LCD. You have to find proper value for your LCD. Try different values or put POT eg. 20kohm and try to set contrast properly
