2nd Chance PI
  • v021
    • Hi,
      Dantech, can you explain the menu option, compare to latests chance is so different, the best I can get for now for coins is about 20cm in high enough area, without annoying sound, stable.
      My problem is, every time I change something like barrier or menu option it's always ringing, the solution is turn it off and on again.
      I use old chance PCB with updated schematic to follow the latest firmware from Andy website. I'm not using 4.7uh choke.
      • I do not understand you little bit.
        This is theread about 2nd ChancePI not original ChancePI
        Original ChancePI firmware and hardware is not supported by me at all at the moment.
        You have to issue suggested by me hardware changes to get optimized for 2nd ChancePI hardware and you have to use my the latest firmware v21
        • Yes I know, you said before somewhere that original updated chance is compitable so I try and works, without omit the parts, you know that my board following your hardware change is not working, and there is no complete PCB layout reference, only schematic, I'm not too good with scheme. And I already use V.21
          • Will someone please confirm for me that pretty much any 12 x 2 Hatachi HD44780 Compatable LCD will work on the Chance ?
            • I use a 16 X 2 display...12 isn't enough.
              Dan
              • One should be 2x16 HD44780 compatible
                • Thank you. 12 was a typo. Yes 16 it is.
                  • Did anyone make 2nd Chance?
                    • Hi,
                      Can you make it to a motion detector? My vulcanic soil is not compromise any non motion detector
                      • What exactly do you mean by "motion detector"?
                        • Originally posted by dantech View Post
                          U need to swing it in motion detector to get the target
                          Motion(dynamic)
                          E.g
                          Garrett 150
                          Barracuda
                          pickin surf pi
                          non motion (static)
                          Felezjoo
                          Clone pi
                          Chance
                          • Hi,
                            Every pure PI detector is static one.
                            I did not see any dynamic PI and I do not believe to see it.
                            • hi dantech
                              thanks for sharing
                              PCB yourself what do you use?
                                Ripsdevala gave you an example of motion PI's: surfpi, pickini, barracuda etc.. So I don't know how you "can't see any dynamic pi"
