2nd Chance PI
    v004
    A few new features:
    - coil delay auto measurement mode
    - 12 timing profiles covering 100 - 1200 pulses per second with proper main pulse width to keep the same power consumption in the entire pps range.
    There are also half power profiles.
    Support for ATmega8 is completly finished because of too small flash memory size
      Thanks dantech,
      The pulse rate selections should be useful for small targets.
      Dan
        Every timing profile eg. 200Hz/140us ensures constant power consumption. I have set it on the level 100mA for full power and 50mA for half power.
        When you change the timing profile you have to re-set main sample dalay also. The higher pps ratio the delay is shorter. Good idea is to use auto delay measurement mode and
        restart electronics when profile is changed.
          v005
          Further improvements features issued in the v004
            Wide range of timing profiles (regarding frequency )in the v004 is completly useless. The same with half power profiles. I have noticed huge VDI instability.
            In the v005 only 3 profiles 100,200 and 400Hz with constant pulse width 120us are issued. Power consumption varies according to the profile. The higher frequency the more power consumed. Maximum power consumption is 130mA. Low frequency can be used as eco power mode
              Why do you bother with power consumption numbers?
              With wide range of high capacity low priced batteries this shouldn't be an issue.
                I do not worry about power consumption in the first line but it is important issue by the way. 130-140mA this is max. acceptable value in my opinion.
                The value is higher than majority of commercial detectors
                Shortening pulses width and increasing pulses frequency has no sense because we loose essential VDI stability and there is no range/sensitivity improvement. Even worse...
                I did a lot of tests.
                So I am forgetting about useless profiles with half power like in the v004
                  v006 is released
                    Re-download v006 again, please. There was small bug
                        Any experience with 2nd ChancePI from field?
                          v007 released
                            i would start build, nice project, thank for share dantech
                            sorry, do you have manual doc for menu?
                            sorry bad english
                            (Indonesia)
                              v007 released , change log?
                                Changelog there is always in the firmware .zip file.
                                You have to use google translator polish - english (or another one)
