0.8mm wir 12turns 304uH
Polish Pi
look easyeda project database, different versions, i used the one from mr freitas
you can order project direct from easyeda or partner jlcpcb
but remind corona virus 2019/20, i can confirm that there is a big delay in production and shipping chain
if you live in europe i can help you out with my pcb
hello there
i have some questions about this project:
1) has anyone measured the power consumption of Polones detector (coils connected)
i'm going to make a 18650 battery pack (4 cells, 16V) and i want to know how many batteries should i use in order to get good battery life in field
like 4 batteries or 2x4 ? (each 2000mAh)
2) i've just bought a polones kit and i found out it is a bit different from the original schematic , it has one more LM741 and couple of 100k trimmers ,i reverse engineered that part of circuit, take a look at these images:
1- the original schematic(i guess)
2- pcb with new components, marked
two red dots are for +5v jumper for the LM741 i believe
3- now other side
4- red parts are the new components
i need to understand how the circuit works so i can fix it if something goes wrong and build it perfectly
so yeah ,if any help i would appreciate that
[ATTACH]49595[/ATTACH]
[ATTACH]49600[/ATTACH]
3- now other side
[ATTACH]49598[/ATTACH]
[ATTACH]49599[/ATTACH]
designer after three days replied : that is for meter!
Originally posted by surfdetector View PostHello Mr. Jaick,
Where did you purchase the kit from? Most of the information that I can find on this detector seems to come from Brazil. It appears to be quite popular there.
Cheers
Originally posted by bernte_one View Postlook easyeda project database, different versions, i used the one from mr freitas
Cheers
Originally posted by bernte_one View Posthi surfdetector,
it would be much cheaper for you to order direct from china
all files are available from easyeda
Cheers
Lucas and polonez.
Opisany wykrywacz pracuje na zasadzie pomiaru zaniku impulsu elektromagnetycznego wysyłanego w ziemie, potocznie takie wykrywacze nazywa się PI (Pulse Induction), wykrywacz ma dobrą czułość, oraz spore zasięgi, i tak - puszkę litrową po farbie jest w stanie wykryć w ziemi na głębokości około 80-100cm, przy cewce o średnicy 40cm, im większa cewka tym większy zasięg na większe przedmioty, można zastosować cewkę ramową, sam nie pr?bowałem ale z pewnego źr?dła wiem że przy cewce o średnicy około 1m wykrywacz potrafi znaleźć przedmiot wielkości 25l karnistra na benzynę na głębokości 6m, co do czułości, z cewką 30cm wykrywa monetę 5zł na głębokości 25-30cm, ponieważ jak już pisałem jest to wykrywacz PI, niema problem?w przy zmianie mineralizacji gruntu, jeśli tylko wykrywacz daje sygnały że coś znalazł to na pewno coś wykopiemy, wykrywacz nie zawiera żadnych układ?w programowalnych, sygnalizacja zlokalizowania przedmiotu odbywa się przez zwiększanie częstotliwości pikania, ja sobie bardzo tą konstrukcje chwale, niema problem?w z uruchomieniem, cewkę nawija się bardzo łatwo, jest to 16m drutu fi 0,5mm na przyjętej średnicy na przykład 30cm, cały stelaż zrobiony jest z rurek do instalacji wodnych - do wody zimnej, wykrywacz zasilany jest akumulatorem 1,3Ah 12V, co pozwala mu pracować około 12godzin,. bez potrzeby ładowania, praca z nim jest bardzo przyjemna, problemy sprawia tylko szukanie na terenach zabudowanych, w obecności zakł?ceń, wykrywacz traci na stabilności, w lesie, na łąkach zjawisko to nie występuje, ustawiamy wykrywacz tak, aby z głośnika wydobywały się pojedyncze piknięcia co około 1 sekundę, po pewnym czasie konieczne okazuje się skorygowanie ustawień potencjometr?w, ze względu na niestabilności temperaturowe itp. nie sprawia to żadnego problemu, część elektroniczna wykrywacza składa się z popularnych element?w, większość z nich to NE555, najbardziej kłopotliwym do zdobycia jest wzmacniacz operacyjny LF357, do uruchomienia wykrywacza wystarczy mieć najprostszy multimetr z pomiarem napięcia i oporności, poniżej zamieszczam schemat i zdjęcia całej konstrukcji, został wykonany w całości przeze mnie, a koszt całkowity nie powinien przekraczać 150zł (sama elektronika około 40-50zł). Kilka uwag odnośnie uruchomienia, w układach generatora i przerzutnik?w mono stabilnych na 4011 stosujemy najlepiej kondensatory foliowe, parami dobieramy opory R12-R13, R10-R11, to samo kondensatory C5-C6 (nie jest to konieczne ale polepsza stabilność), po włączeniu całości i odłączeniu sondy (L1) potencjometrem montażowym PR2 ustawiamy na nodze 3 układu IC4 częstotliwość 100Hz jest to częstotliwość optymalna, można eksperymentować z jej ustawieniami, trzeba uważać żeby nie przegrzać tranzystora T1, w następnej kolejności podłączamy sondę oddalamy ją od przedmiot?w metalowych i potencjometrem montażowym PR1 kręcimy do momentu kiedy sygnał w głośniku zniknie, sprawdzamy czy mamy możliwość regulacji częstotliwości generowanych dźwięk?w za pomocą P1 i P2, jeśli tak regulacje wykrywacza można uznać za zakończoną, potencjometr P3 służy jak łatwo się domyśleć do ustawiania głośności. Dokumentacja wykrywacza dostępna jest tutaj.
Galeria zdjęć:Attached Files
hi surfdetector,
i checked the postal pricing list from DHL
maybe i can send you a pcb as letter for 3,70?
send me your adress via p.m.
i use a chinese lf357, but it is one of the best clones i had from aliexpress
i use same type in felezjoo
https://www.youtube.com/watch?v=qU1bF0atZDA
