How much frequency shift should there be to help reject interference on a pulse detector using the 555 timer as the oscillator...for say searching on a beach !!! will say a 1k or 2k potentiometer give enough frequency shift ???
FREQUENCY SHIFT CONTROL
i want to add an external frequency control to my detector to tune out interference...if say my tx frequency is 3 khz then how much shift would i need like what value potentiometer would i require like 1k...2k..5k so i can frequency shift either side of the 3 khz tx frequency.
when im on the beach i get interference from amusement arcades and other detectors if close to me so i want to try and minimise the interference with a control but not sure how much of shift either side of 3 khz that is required...maybe + or - ...250 hz either side of 3 khz ????
I have been using a PI designed by Cyril B. Smith named the Manta (similar to Svens Mirage) where he implemented a dual gain front end for faster sampling and a frequency control of 1800 Hz with a 10% adjustment range. I find it to be highly effective at eliminating EMI. Even inside the house I can eliminate almost all noise with careful adjusting. I thought about adding this feature to some of my other PI projects as well.
Don.
Originally posted by dfbowers View PostI have been using a PI designed by Cyril B. Smith named the Manta (similar to Svens Mirage) where he implemented a dual gain front end for faster sampling and a frequency control of 1800 Hz with a 10% adjustment range. I find it to be highly effective at eliminating EMI. Even inside the house I can eliminate almost all noise with careful adjusting. I thought about adding this feature to some of my other PI projects as well.
Don.
Is this a detector that is available?
