GOLDSCAN 5 SCHEMATIC QUESTION
Originally posted by Altra View PostHere is the audio section from the TDI Pro proto-type.
I bread boarded the circuit using a CD4046 instead of the AD654. Also used 2N2222's for the npn's and PN2907's for the pnp's.
Probably some mistakes, but easier than looking at photosOriginally posted by Jose View PostThe first part of the GS5 scheme has errors.
What I am publishing, is my version based on the Turkish scheme but with the corrected errors.
It may be something different, but it is working.
To differentiate the Turkish scheme, call it GSX5JB.
Jose
Many thanks for these posts. Very usefull.
Jose, about the GSX5JB, your drawings looks like using the CadStar CAO. Is it ?
Originally posted by Jose View Post...To differentiate the Turkish scheme, call it GSX5JB.
Jose[ATTACH]41051[/ATTACH]
Originally posted by Davor View PostI noticed you put D7 a normal silicon diode. It should be a Schottky. Its function is to prevent JFETs gates from conducting when forward biassed. Trouble with JFETs is that a gate-channel barrier is lightly doped, so the gate-barrier diode forward voltage is lower than that of normal silicon diodes, and therefore a normal diode can't prevent JFETs from conducting in this configuration. Try BAT85 instead.
Originally posted by Altra View PostDouble check for errors!
Integrator inputs are wrong.
Originally posted by Davor View PostI noticed you put D7 a normal silicon diode. It should be a Schottky. Its function is to prevent JFETs gates from conducting when forward biassed. Trouble with JFETs is that a gate-channel barrier is lightly doped, so the gate-barrier diode forward voltage is lower than that of normal silicon diodes, and therefore a normal diode can't prevent JFETs from conducting in this configuration. Try BAT85 instead.)
2K2also makes the gain half of the previous sheme.
https://www.vishay.com/docs/88748/ss22.pdf
Eclipse is correct about the integrator inputs reversed. The integrator is a TL062, the next 4 amps same page are a quad lt1114. The audio gain stage is a LT1112. A quad TL064 is used for the absolute amplifier with one of the amps unused. I drew this for reference not to clone. If people find something they question circle it on the schematic and post. I will try to verify.Attached Files
Jose
Originally posted by Orbit View PostDoes he alter iron tone „instantly“ after crossing above the iron target ?Does it work on 3khz and what is the width of the pulse ? Thank you Nenad !
Press width TX use 100 useg.
The frequency, 3; 3.2 Kz
Sample 15 useg. separated 100 useg for the second sample.
Identical GB channel, the separation between both channels is 20 useg.
The points marked A, B, C, D, in my scheme, they have no relation to the Turkish scheme.
Jose
