GOLDSCAN 5 SCHEMATIC QUESTION
  • Originally posted by scs View Post
    Patience! You will soon see my easy to make Pi discriminator schema. It works great.There is no point in discover the hot water.[ATTACH]42057[/ATTACH]
    sounds good thanks SCS
      True. How does one distinguish a good schematic among many that contain errors in the same thread? I start from the assumption that all contain errors, however minor. Even some published schematics from Companies, deliberately contain errors.
      With any schematic posted or published one needs to go through each stage and Understand how it works.Then at least the simple errors like backwards op-amps and transistor are found.The TDI Proto schematic is Full of these errors. Not sure if that was intentional or this schematic was just a Very Preliminary one for the 'general' signal flow.
      The hard errors to notice are wrong component values.
      IF you understand the circuit, example is the 47nF cap across the feed-back of the Hammer Head II Pre-amp, then a value way out is easily spotted. The cap/resistor values for the Timing circuit in the TDI Proto could be why off. Also, I doubt that the TDI, even the first ones, actually used the timing on that proto schematic.
      Sometimes these value errors are due to Copy/Paste of parts and then forgetting to change the value (done this).
      Last, one should Prototype any posted schematic or at least stages to ensure it actually works. This is what I did to build my version of the Hammer Head circuits (see my thread "my take on the HH2" in the HH II sub-forum).
      • My idea is testing every section separately, correct of errors and put here correct sehamatic and pcb file.
        Now i see timing section AB and CD timings are same and i dont understand who is 1 sample and others because now C ,B is about 10us from TX and DA samples is about 120us from TX
        • The time base that I use in GS5XJB. For the synchronization with the integrators see the scheme, or compare with GS4 Alexismex.Click image for larger version
Name:	Time GSX5 Jose.JPG
          • Thanks my friend
            • Pic for Tdi .Click image for larger version
                Pic for Tdi .[ATTACH]42123[/ATTACH]
                It looks very professional!
                • Originally posted by Jose View Post
                  Thank you, Jose!
                    SCS any progress on your design ???
                    • Hi,please someone explain what is chip and how it work?
                        The simple errors are easy to spot as you say like backward opamp wrong pin numbers etc. But wrong values for components and wrong circuit connection are difficult problem for novice like myself. I can work out most errors by going through each stage and maybe comparing with other similar type circuits, even running simulation to understand what's going on and how each stage works. Most errors can be found, but still, there are some that are very much hidden, even for expert.
                        • Can you put whole schematic? It looks like power supply section, but can't see the image is blurry.
                          • Originally posted by saba View Post
                            [ATTACH]43180[/ATTACH]
                            It looks like the power supply section. Put whole schematic, I can't make out, the image is blurry.
                            • It is Orbit schematic, not so clear
                              • 7660 / LT1054 is used to double the +Bat voltage (0 to 12V from battery becomes 0 to ~24V on the output) then it's regulated down to 12V + 5V = 17V.
                                Look into Minipulse Plus for example it's used there and many other circuits out there. It also can be used to deliver negative voltage. Image is too blurry.
