orbit do you know how whites got the audio threshold so stable in the TDI sl version even at max sens setting ???
GOLDSCAN 5 SCHEMATIC QUESTION
Originally posted by daverave View Posti have modified two of my detectors to work down to 8 uS and work fine on the dry sand but on the wet sand too much chatter and thats why i wondered if a bi polar coil drive would eliminate the chatter at low delays...so is it only on inland field sites that the bi polar coil system will eliminate the ferrous ground effect ???
What you're referring to for inland sites is called viscous remanence magnetization (VRM). Carl should be able to give you a more detailed explanation on this.
Originally posted by daverave View Postorbit do you know how whites got the audio threshold so stable in the TDI sl version even at max sens setting ???
Yes I know but I think it's TDI still a commercial device , although there are some other ways that the threshold of the tone be silky without ipon effect,I do it on my analog detector , moreover it can make even less noise than the original TDI SL..
Originally posted by daverave View PostHello Qiaozhi....when you say a bi polar coil drive minimizes the problem of magnetizig the ground so does that work the same for wet sand and does that allow the use of lower delays without chatter on the wet sand...also does anyone have a diagram of a bi polar coil drive that can be used for any pulse detector.
https://www.geotech1.com/forums/show...ighlight=af108
Originally posted by daverave View Poston youtube some claim they can use a delay of say 7 uS on wet sand using the fisher AQ which has a bi polar coil drive from what i see...so im a bit confused
I think I've found the youtube video you're referring to. On the front panel of the Fisher AQ there is a control marked "Reject" which is labelled from 1 to 12, and I notice that the default setting is 6. I suspect these numbers do not refer to the actual main sample delay.
Hello Qiaozhi....its just all confusing as i asked someone on youtube who was using a fisher AQ about the 7 uS delay setting and they told me they could use the 7 uS setting on wet sand without chatter but they said in the surf if the coil is swept in the waves then the detector will chatter
Originally posted by daverave View PostHello Qiaozhi....its just all confusing as i asked someone on youtube who was using a fisher AQ about the 7 uS delay setting and they told me they could use the 7 uS setting on wet sand without chatter but they said in the surf if the coil is swept in the waves then the detector will chatterAttached Files
In the sale brochure it claims "as low as 7us". I recall the designer stating that careful construction of the coil and digital processing allowed for short delays in wet salt. Also the AQ is not bipolar, Tartar said he has one in the works. Carl could clear all this up.
First post in the link has a sales brochure
https://www.detectorprospector.com/f...l-information/
Originally posted by daverave View Postsomeone told me the whites tdi sl has a fake threshold that gives a more stable threshold
Originally posted by Qiaozhi View PostThere's nothing on the front panel that indicates micro-seconds.
