Thank you for making lay6 great radio work the file
<HUGE text file deleted>
This is not the way to attach image files to the forum. It results in a huge text file that causes problems loading the page.
The correct way is to click on Go Advanced, and then select Manage Attachments.
Thank you Walkman. I'm building the Voodoo at the moment but I would like to build your version of the XL-500 also. I tried to build the original but I could never get it to work. Thank you again. Regards, Marty.
Thank you Walkman and Emersonpaz. @Walkman,,,Could you tell me what these are please on the photo I posted? Thanks, Marty.
The yellow box marked 25K, appears to be the NON-FE.DISC 25K pot that goes from one end of the 4K7 resistor and the other to +12volt, its looks like a pcb pin hole is provided in the +12 volt copper to solder in to/on to.
The other yellow box is the audio section which has some variations.
I might have written that poorly, so the area within the yellow box which contains the figure 25K, etc etc
Thanks guys,,,Only I couldn't figure out where to connect the speaker? @Constantin,,,Have you built this version? How do you know the Power supply section doesn't work? Thanks, Marty
