Totem-pole gate driver VS Active pull down VS Fast Fet turn off
  • Please forgive me for my simple questions.
    I'm going to build HH1 Rev. D because it has an independent audio part. Actually, i want to use a Non-VCO mode with a fixed sound like TDI.
    Please see the link, it's an online tone generator. Please set frequency for 600Hz and hear it, square type. Do you think i can generate such tone by changing R55?!
    Thank you for your helps. I need to thank you for All, especially Mr. Qiaozhi and Mr. Carl because i learned many things from PI and etc. in thins forum.
      As far as I can see there is no R55 in the HH1 schematic.
      The non-VCO option uses the TX oscillator as the audio tone, and this can be adjusted with R2.
        Yep RevD r55 1K pin7 IC9
        • My mean is HH1 Rev. D, Pin7 Ic9. Do you think we can such tone by changing R55?
            Hello
            Dear 6666
            Have you tested this, Non-VCO? Do you think we have such tone (exp. 600HZ) by changing R55?
            In Rev. C, Non-VCO is very strident. It seem that sound is very very sharp and bad. For exp, i set my TX over 900Hz and compared my output sound with 900Hz in the link tone generator. I think the two sounds are very very different, especially my HH1 very very strident. In addition, my sound level in Rev. C is very weak so that its volume dose not increase, do you think it's normal?
              Sorry - I must have been looking at the REV-C version.
              • Dear Qiaozhi
                During last 10 years, has anyone been able to add GB to HH1 like TDI ?
                  Dear Qiaozhi
                  Not HH1 but check my thread on how I do GEB on HH2.
                  https://www.geotech1.com/forums/show...ake-on-the-HH2
                  • Thanks dear waltr.
                    Do you think HH1 is able to detect high depth target?
                      Define what you mean by "high depth target".
                      • Hello
                        Dear Qiaozhi.
                        Please see attached, i added GB and Gain control (from Mr. Walter schematic) to HH1 Rev. D. Can you tell me your opinion?
                          My mean is reaching sensitivity to commercial detector like TDI.
                          • Sorry, I edited schematic, Audio part.
                              Thanks dear waltr.
                              Exacty....I have detected a soda can at nearly 2 feet down. Got a US large cent coin at 12 inches. Is this what you mean?
                              [ATTACH]55033[/ATTACH]
                              Not sure if that will work. One sampling switch is for target sampling the other is for EFE.
                              That is not what I did to add GEB.
                              • Thanks dear Walter.
                                I tried to follow Carl's book method (attached). I think its method only uses two samples, target and EFE
