Totem-pole gate driver VS Active pull down VS Fast Fet turn off
    Actually, i want to use a Non-VCO mode with a fixed sound like TDI.
    TDI does not have a fixed sound, it has VCO audio. But yes, you can set the Rev D audio to whatever frequency you like.
    Originally posted by h9361 View Post
    Please see attached, i added GB and Gain control (from Mr. Walter schematic) to HH1 Rev. D. Can you tell me your opinion?
    You still need EFE sampling. This is where a micro saves a lot of logic chips.
    My mean is reaching sensitivity to commercial detector like TDI.
    If you are very experienced in PI design it might be possible to achieve something close to a TDI. If you do not have the experience, then no.
      Hello
      Dear Qiaozhi.
      [ATTACH]55032[/ATTACH]
      Carl (designer of the HH) and waltr have answered your question.
      As Carl says, adding a micro would make things a lot easier. In that case you would be better to follow waltr's HH2 version with GB already added.
        Hello
        Dear Qiaozhi.
        I read your posts about GB. You posted two different posts, please check parameters the in the links.
        I think S2 and S3 in your formula is different, which of them is true?!
        https://www.geotech1.com/forums/show...ght=Hammerhead
        https://www.geotech1.com/forums/showthread.php?23802-Detection-distance-ground-vs-air&p=229548#post229548
          Hello
          Dear Qiaozhi.
          The above links point to a thread, and not a particular post, so I'm not sure which equations you're referring to.
          I believe the following are correct:
          S1 = main sample
          S2 = GB sample
          S3 = EFE sample
            S1 = main sample
            S2 = GB sample
            S3 = EFE sample
            So, which of them is true?
            A1(S1 - S3) - A2 (S3 - S2)
            Or
            A1(S1 - S3) - A2 (S2 - S3)
              Or
              The correct equation is here:
              https://www.geotech1.com/forums/show...715#post182715
                Or
                Oh dear. Houston, we've got a problem.
