HELLO CARL :) recommendation please?
  • HELLO CARL :) recommendation please?
    hello carl. i would like to ask a recommendation from you.
    what would be the best detector or PI detector that is capable to detect at a minimum or at least 2 meters depth with high mineralization soil just like here in the philippines? because most of the detectors used here can detect at shallow depth.
    i want your best recommendation for that DIY with complete PCB layout, coil design and programs that can be found in our group.
    if there would be a 2 feet by 2 feet coil will do. you can post here the link.
    thank you so much carl
    What are you expecting to find at 2 meters depth ?
      i think gold mask 15x15 cm.
        The correct question asked 6666. Answer and you are not joking (a gold mask 15/15 cm).
          Gold bars ������ or any other possible metal..
          For 6666
            Thank you bro. Can i find a complete pcb layput,parts list and program here?
            For kt315
              Thank you bro ��
              For filos
                Is it the most easy diy with the best result when it comes to high minerals? Because lots of detectors are great when it comes to air test but if you bring it here in the philippines,in can only detect about 1foot or less..i want to build a simple yet accurate PI..
                For kt315
                  There is no such detector to operate on the principle of pulse induction and to detect an object at 2 meters deep in highly mineralized soil. With a 1 x 1 meter antenna, you may be able to find an object the size of a large tractor, truck, tank or airplane.
                    kt 315, my very best friend and bro
                      For kt315
                      yup. Eric Foster works hard to do PI working in high mineralized conditions. thats problem.
                        Yayks??really?? Thank you bro..
                          What should i use in highly mineralize soil? What are your reccomendations?
                            [ATTACH]47313[/ATTACH]
                            What are your recommendations?
                              Is VLF good in highly mineralized soil?
