You are doing something wrong or you have connected some lines at some point during soldering. Get a better soldering iron for electronics, not for construction gutters. Or some of your components are faulty. What doesn't work? As we can all see, you haven't soldered everything yet and you claim that it doesn't work.
Pulse Star II (first analog version)
Originally posted by Orbit View PostYou are doing something wrong or you have connected some lines at some point during soldering. Get a better soldering iron for electronics, not for construction gutters. Or some of your components are faulty. What doesn't work? As we can all see, you haven't soldered everything yet and you claim that it doesn't work.Attached Files
Under 1, are you drunk or crazy? The second record does not exist and it is the original. Under 2, you should explain what is not working. If it beeps without the coil and works with the coil on then replace Lf357 with 411 and probably some ic is faulty replace tl064 with lf444.
Originally posted by Orbit View PostUnder 1, are you drunk or crazy? The second record does not exist and it is the original. Under 2, you should explain what is not working. If it beeps without the coil and works with the coil on then replace Lf357 with 411 and probably some ic is faulty replace tl064 with lf444.
