1.2 n was in one of the units, in the other it was 1nf, that capacitor affects the width of the transmission pulse, nothing significant affects the operation! The device works with both 1nf and 1.2nf. You yourself made a mistake on the pcb and no one can help you but you! As someone said solder another pcb no one can help you.
Pulse Star II (first analog version)
Jumpers are often required for 2-sided PCBs and usually are not included in the schematic. This is normal.
Repeating over and over that the schematic or PCB has errors is not going to solve your problem. Multiple people have said it works, so it's time to try a different path. Troubleshoot your circuit and figure out what is wrong with it. Start with the power supplies, then the timing, then the TX, then work your way down the RX. It will probably help to redraw the schematic in a more readable form.
in Pulse Star II Pro author used two PIC micros and did not use the black epoxy, no need. the PICs have the protection bite.
Originally posted by eduardo1979 View PostHello Ivconic.
I just received my Pulse Star 2 from Aliexpress. Congratulations on the great work you've done.
Thanks to you I have had the opportunity to test this detector.
Best regards,
Eduardo.
Originally posted by eduardo1979 View PostHello.
The integrated circuits are completely erased and absolutely nothing is visible. I assume they are: TL064, CD4066, CA3130, and LF411.
