The analog circuit is outdated. The analog circuit is too complicated and noisy to make an excellent detector, so I hope you can do digital pi together, so that the circuit is simple and the performance will be better
PI 1234567890 PI
Originally posted by Carl-NC View PostHave you done a noise analysis for each design, with a preamp and without a preamp?
Originally posted by liudengyuan View PostI have measured the waveforms at both ends of the coil. In the absence of a preamplifier, the noise is very small. Of course, the voltage at both ends of the coil I am referring to is limited by a damping resistor and a diode.
Originally posted by liudengyuan View PostCan we directly sample the coil with a 24-bit ADC chip without using an operational amplifier?
A preamp introduces noise to the overall response but so does an ADC. You need to do a noise analysis to determine whether the ADC alone (no preamp) is better than a preamp+ADC. My bet is overwhelmingly on the preamp+ADC. And if I wanted the absolute maximum depth, then my bet would be on preamp+demod+ADC.
I think you are looking for a quick easy solution (with people telling you how to do it) and there is none. Build one of the projects on the forum and experiment. You will quickly see how hard the problem is.
Originally posted by Carl-NC View PostIn the absence of a preamplifier, a target response is also very small. You can't tell much by looking at the raw coil signal on a scope.
