Optimizing Target Responses
  • #76
    Yes, better late than never!
    Part 5: Real Responses
    So far we've looked at different responses and applied piecewise-linear solutions to much of it. That is, the PI turn-off was a linear ramp that induced a step EMF in the target. This is a good first-order approximation and a good way to do quick-n-dirty comparisons, like what happens when you try to get a sharper & sharper turn-off slew rate (Part 4).
    In reality, the PI coil is an RL circuit during turn-on and an RLC circuit during turn-off. Equations can be derived that accurately describe what they do. I won't derive them here but rather just toss them out. ITMD3 will have full derivations.
    The turn-on equation is simple:
    The turn-off equation is non-obvious but here it is:
    where is the peak current at the turn-off event.
    Let's look at a realistic example...
    Measured coil parameters:
    L = 300uH
    Rs = 5 ohms (total series R)
    SRF = 500kHz (inc. cable etc)
    VTX = 10V
    The parasitic C for the coil is
    The require damping resistor for critical damping is
    Now calculate the taus:
    VTX (10V) and Rs (5 ohms) tells us the max flat-top current will be 2A. The TX tau os 60us so we would need a TX pulse width of ~300us to reach the flat-top current. A more normal TX pulse width is 100us which makes the calculated peak current 1.62A at turn-off. This becomes the starting point for the turn-off equation.
    Here are both equations plotted in Excel. Note that the turn-on curve spans 100us whereas the turn-off curve spans only 3us.
    Also note that in the turn-off side the tau_RX is 318ns. If you are expecting the current to be substantially gone in 5*tau (1.59us) you can see it is not. The 0.67% mark occurs at about 2.25ns which is about 7*tau, about 40% more than the usual RL curve.
    But that's not the worst part; let's also look at the flyback voltage. Its equation can also be derived:
    We have all the variables from above; the curve looks like this:
    This curve is also plotted to only 3us. The peak hits ~560v which can be calculated from the derivative of the above equation. Note that the peak occurs at exactly tau_RX. If you were to assume that any kind of 5*tau settling applies here, then you would take 0.67% of 560v (=3.8v) and see that it occurs at about 2.57us, which is about 8*tau.
    But this is the raw coil voltage which is then applied to a preamp with a fairly hefty gain, perhaps 500. It's immediately obvious that 3.8v will seriously overload the preamp. To determine a realistic required settling we need to make an assumption: that the preamp must be, say, within 0.5v of settled for the demods to work well. For a gain of 500, this means the coil voltage must be within 0.5v/500 = 1mv of settled. In the curve above, this happens at about 5.42us, or 17*tau.
    You might be thinking that 5.42us is pretty darned good. But this is strictly the coil settling; the diode clamps and the preamp overloading have not been accounted for. And everything above assumes the MOSFET never avalanches.
    [ATTACH]54867[/ATTACH]
    [ATTACH]54866[/ATTACH]
    Hello - really enjoying reading this thread but ... the equations are not rendering. Do I need some special plugin or something?
    thanks
    paul
    • #77
      Have you tried a different browser?
      • #78
        thanks
        paul
        On my android phone. The equations are missing for me also on part 5. In other posts, same thread they are okay. Maybe the part 5 attachments are corrupted?
        • #79
          Yes - Chrome and Edge on Windows (different PCs) and Kiwi on Android. All the same - just show a little icon as if there should be an image for all the equations.
          If I 'inspect' the icon the page source shows an <image> tag with a source url that contains what I think is LaTex code. I guess there should be a server-side cgi plugin to convert the LaTex code into an image format?
          paul
          • #80
            So the formula rendering issue seems to be due to html <br /> tags that are embedded in the img tag src url, eg:
            <img src="http://www.geotech1.com/cgi-bin/mimetex.cgi?<br />
            v_{off}(t) = \frac{I_0}{C_L}\cdot t \cdot e^{-t/\tau_{RX}}<br />
            If I remove these (in Chrome DevTools) then the formulae are displayed correctly.
            • #81
              In the above quote I have removed the CR/LF after the opening latex and before the closing latex tags. This results in the formulae being displayed instead of the broken image link icons.
              paul
              • #82
                paul
                Have you tried Firefox?
                I'm using Firefox on Linux, and it displays just fine.
                • #83
                  Works for me in Firefox, but not Edge.
                  • #84
                    Can you see the formulae in the quoted part of post #81 in Edge?
                    • #85
                      Yes
                      • #86
                        I can see it correctly on all my Apple devices, Macs and iDevices but under Safari and Chrome. Some are very old and some are new.
                        • #87
                          Just to confirm that I cannot see the equations in Part 5 with Chrome on my Android phone.
                          However, I can see them in post #81.
                          • #88
                            OK, I've fixed all the equations, at least they all show correctly in Edge. The problem (as pointed out by Repwoc ) was the following:
                            This does NOT work:
                            [.latex]
                            latex equation
                            [/latex]
                            But this does work:
                            [.​latex] latex equation [/latex]
                            I'll try to remember that. Thanks for figuring that out.
                            • #89
                              Yep, that's done it. Equations now showing in Chrome and Edge on Windows and Kiwi on Android.
                              • #90
                                Is it possible to simulate a target response in a PI detector circuit in ltspice? I'm guessing that I'd have to add a coupled inductor to the circuit but not sure how to connect it.
