Two jobs done so far. First was to change the 7 cell Nicad pack for something better and lighter. Now I use 3 Li-ion cells which are half the weight and much bigger capacity. I've used protected cells to avoid draining them if the detector is inadvertently left switched on. Charging circuit needs to be changed too. The electronics at the moment draws 150mA so the added capacity will allow running at a higher rep rate to speed up the response which is a bit slow at present. TX pulse width is 200uS so I will look at increasing that too. Mosfet will be changed for one with a lower Rds.on and a series diode. I will remove the IC's from the RX chain and put in sockets so that alternative devices can be tried. Several other things could be changed but this will do for the present. Oh yes, I changed the twisted wires from the coil socket to a miniature coax. The problem with this case is that the connector is on the bottom and very close to the pcb pads for the coil. To withdraw the electronics for testing then requires a long internal cable if the same connector is to be used.
For Vadim18 input resistor 1K and feedback resistor 1000K for OPA37. For KT315, sheet too large for my copier and out of date with 3055 TX and 709RX.
Eric
Eric
