Crossbow Classic
  • Crossbow Classic
    I have Rev B edition Gerber files. Is there a Rev C available out there?
    If not and I decided to go ahead with the Rev B build.
    Is there sufficient info / assistance available in case I get stuck?
    As I understand. The Crossbow was never fully completed and went into part publishing before finalization with only one builder making a success of it.
    There were 13 Crossbow detectors built using the REV-A board. After that the design was sent to Sven and subsequently there were REV-B and REV-C layouts created.
    Please be aware that the Crossbow is a complex design that is not suitable for beginners, and there are no build instructions.
      Thanks Qiaozhi
      Is this not enough to build from?
      Not sure where I got it.
      Inspiration came from a YT channel.
        Thanks Qiaozhi
        To be honest ... NO.
        That's a set of notes made by someone who was a member of Sven's website. It doesn't even include a schematic.
        You would be better off building the MPP Rev-E, which can achieve near to the same depth if set up correctly. Otherwise you could try building Hammerhead, which comes with an excellent article written by Carl. The Crossbow is a derivative of Hammerhead, so you should be able to achieve at least the same performance.
          Ah Ok.
          Thanks for setting me straight.
          Learning every day on here.
            there is a crossbow up for sale on eBay AU.
            there are some good photos if anyone wants to have a look.
            They want $1500 for it.
            https://www.ebay.com.au/itm/Crossbow...frcectupt=true
              Blimey!
              Let us know if it sells for that price.
              It's an original Crossbow, but with a straight stem.
                I finished my build of the Rev C version last week. It was an interesting and successful build and I believe that I will package this one up 100% to use at the beach.
                  Well done.
                  Be prepared to dig some deep holes.
                    Blimey!
                    AU $1,400.00
                      Well done.
                      George,
                      Do you perchance have the spec or model of the aluminum enclosure that was used for the Crossbow? I like the look of it and would like to get one for my clone if possible.
                      Thanks.
                        George,
                        Thanks.
                        The enclosures came from Lincoln Binns -> https://lincolnbinns.com/uniobox-2.html
                        It was a Uniobox 2, width = 104mm, length = 160mm
                        They also offer a hole cutting and laser printing service -> https://lincolnbinns.com/customisati...nclosures.html
                        The PCB was mounted on a carrier plate (supplied by Lincoln Binns) that slotted into the side rails -> https://lincolnbinns.com/shop/alumin...cessories.html
                          Thank you for the information.
                            Same here. My boards arrived on Friday and it was completed today. Maintains a strong signal where others trail off.
                            Nice project you created there George.
                              Hi, looking for the Rev C Gerber files.
