Which one do you guys like or prefer more? I want to build one of these and would love any suggestions. Also i am beginner and i dont own an oscilloscope so thats why i have these two in my list. Also let me know how do they compare with hammerhead in depth
Surf pi VS geotech baracuda
Whatever someone tells you will always be different from the experience you will get from working with your detector. My advice is to make both detectors. They are not complicated to make. But for the coil you will need an oscilloscope to be able to choose the right damring resistor.
If you do not select the dumping resistors, the detector will work, but you will not have the maximum of its capabilities.
The surf is a little bit easier to make because it uses a 4066 as the sample switch not fets as with the barra
the damping resistor needs to match the coil that you make, many ccts show a 390 ohm resistor this was for a coil of about 260uH
some ccts show a reverse parallel diode with the battery if you use that diode make sure you insert a fuse inline before the diode
instead wire it in series .
Originally posted by K tech View PostI am ready! i will be making baracuda. I have ordered pcb for it also can i use j112 instead of 2n5484 and 2n5485?
Geotech Baracuda - REV-A - Project Details
