Surf Master Pro
  • Surf Master Pro
    Problem Surf Master Pro Dead there is nothing Is there an error Thanks for the helpClick image for larger version
ID:	371687Click image for larger version
ID:	371688Click image for larger version
ID:	371689Click image for larger version
    Learn to solder properly
      they COULD made... they did put 100...200...300 tons rock blocks ideally easily without the gaps between them...
      but something happened... and now they can not even solder properly (((
      https://www.youtube.com/watch?v=OSQl-VcM5rM
        Thank you I do
          Yes, I can place the stones correctly
          And I can also put you inside a bottle
            Hammerhead jumper's with enameled wire should have removed the enamel from the ends before welding.
              do a test maybe you are not driving the jumpers
                Yes, my friend, I remove
                  follow
                    Hello everyone is it possible to install Mosfet 840 Instead of Mosfet 9540
                      No, the IRF840 is an NMOS device. Won't work.
                        Thanks Mr. Karl
                        Great honor for your concern:قبعة
                          Thank God, the device is working now, but the sensitivity is weak
                          Please, Mr. Carl, what is better coil make itmake it
