New PI-Tech forum
This is a sticky topic.
  • New PI-Tech forum
    PI discussions have always dominated Geotech. I've decided to move the PI stuff into a separate forum to make finding things a little easier. It will take a while to go through the 5400 threads in the Tech forum and pick out all the PI threads. I am starting with the most recently active stuff and working backwards.
    Done through 2002
    And where is the link?
      You are already in it, just go to top of this page.
        Good idea , very big job, only catch is our book marks will not work for moved threads.
          Then how to understand this phrase of Carl?
          https://www.geotech1.com/forums/show...-replica(tion)
            Go to top of page, click forum, look in Technology, you will see new forum "General Detectors" forum. the thread is in there.
              Aaaa .. Everything .. found))) I was looking at the top of the page, and it is below. Thank you!
                If you bookmark using URLs they will still work. For example, the URL for this thread is https://www.geotech1.com/forums/show...-PI-Tech-forum. Notice that the URL does not refer to the subforum at all. I can move this thread to a different subforum and the URL will be the same.
                  Thanks , that's good news.
                    Thank you for everything you do for this forum...valuable effort Mr carl
                      Hello, I am looking for documentation for an analog PI metal detector that can eliminate fine steel (Fe)
                        Hi hunter63,
                        This is our common dream - to design PI metal detector capable to eliminate fine steel in every soil !
                          first main rule. do not go at the places infected by ferrous.
                          second rule. go at gold nuggets fields. dig the gold.
                            Hello
                            Ha Ha Ha there are no gold nuggets in the Netherlands, but Rome is beautiful, I have a Gmaxx 2 detector whose range for small coins ends at 35cm, I want something more powerful​
                              why you can not to try build George's THE WOODOO? what clog barrier is there for you?
