Its "OK" that you make fun out of such claims because it shows that "criticism-thinking"
saves you from pain and losses and you must not believe what some liars and betrayers
wanna tell the people just for exploiting them by false-informations and shiny illusions !!!!
BUT:
Do you know that you can listen to some very weak radio-station from 5000 km away if
your receiver is ultra-sensitive and filters out all kind of disturbances including perfectly
for this frequency fitting and adjusted antenna ??? Do you know this, hm???
With your little super-short-limited MD-antennas ...
I have told it already 5 years ago that if you can bring the signal-noise-ratio to it's limits,
you can easily get the doubled depth out of every detector compared with "amateur users".
Or what do you think what I am doing with the Garrett Pro-Pointer by just adding some
a little bit turn-around-able screw since 10 years! I'm getting the double depth out of it!
Create the hell less noisy circuits and reduce the EM-field disturbances !!! Or I will do it!
And don't claim it is depth if the coin has to be at an area of 1x1cm in the middle of the
coil so it becomes detected from 80cm away but over the whole diameter of the coil !!!
Hahaha, or do you want to search every single MILLIMETER so you have your coin exactly
inside of the center of your coil ??? You have to run around fast and the coils-diameter will
provide already a sucessful depth or better said: Overall surface-coverage!
Otherwise you will need a half day to search just an area of 10x10 meters! Hahaha
BUT:
