Thank you!
Thank You, Carl!
But still not clear; can i use lower resistance coil than without risk to warm fet or even get it hot and blow?
"To reduce coil current, you need to add a few ohms of resistance in series with the coil."
That resistance should be resistor but high power (5w,10w) or 1/8w or simillar? Or does'nt matter?
Pulse Star II machine used with coil 2 ohm resistance and high power in it does'nt blow fet, but Delta Pulse even with 3-4ohm coil a less power blows fet?? How come? Even freqency is lower (150Hz) than at PSII...???!!!
:confused:
Thank You, Carl!
:confused:
