Delta Pulse
  • Delta Pulse
    Hi, i really dont know anything about the performance, i m trying to build my first delta pulse with sprint layout pcb. I compared it with mikron electronics schematics and i found some track diferences when i compared with sprint layout file. That´s the reason because i m requesting the schematics of it. I also had place the components names on the pcb, but the ones that are show on Mikron Electronics schematics.
    If any one can help i ll appreciate it.
    Nelson
    PD: i m sending the pcb on spring layount format with the components names placed by me.
    • Delta pulse sprint layout pcb
      Here is the original pcb file on sprint layout format
      • CD4538
        Hi Aban and 1843. I looked at technical data of CD4538 and NC14538. There is a little difference at pin 5 and 11 (input A and B). MC14538 has a non invert schmitt Trigger in serious that CD4538 has not. So I am not sure if you can place MC14538 istead of 4538. My opinion is to try with cd4538. If i will find a mc14538 i will test my Delta Pulse and i write you
        • Delta pulse MD
          Hello Treiti or anyone that can help please.
          Is possible that you send to me the DP full file placed on http://www.treiti.times.lv/shem/deltapi_v1_treiti.zip , because i can get it from that link address.
          My email is ce3llp@mi.cl
          In advance many thanks
          Best regards
          Nelson
          • Thank you, Geo!
            Hi Geo,
            I want to build a 60cm rounded coil for DP, Tell me the information for it,please.
            Aban
            • Originally posted by 1843 View Post
              Hi Geo,
              Aban
              Hi Aban. With 23..25 turns of wire 0.5...0.7 mm you are OK
              Good luck
              Btw i made a square coil 60x60 and it works very good. I think that i made it with 23 turns (no very sure but near 23 turns)
              • Wire gauge
                Hi Geo,
                Can I use the 0.4 or 0.8mm wire?I think that 0.8mm is better than 0.6mm.
                If I use the 0.8mm wire, How many turns is needed?
                Thank you
                Aban
                  Hi Geo,
                  Thank you
                  Aban
                  Hi Aban. The turns are the same but if you use 0.8mm you must measure the DC resistance of coil. If it is lower than 2.5..3 ohm then connect a 2..4 ohm resistor in series with coil because the IRF740 will come Hot
                  • Square or Rounded coils
                    Hi Geo,
                    Square coils are better or rounded coils?
                    Does need a 60cm square coil to shielding?
                    Can DeltaPulse detect 1to 2Kg gold at 2 to 3meter under the soil with 60cm coil?
                      Hi Geo,
                      Hi. For me it is the same. The choise of square coil is that it was easy to build the coil housing. I made it from pvc water pipe. I believe that 2 m coil is suitable for you . Try it with 8 turns 1mm wire and maybe a resistor 2.5..3 ohm in series with it. It don't need shielding.
                      I never found gold so i don't know for sure if you can detect it.
                      Good luck
                      • Good Luck
                        Hi Geo,
                        Good luck
                          Good luck
                          The 2m coil is very big! I can not carry it!
                          I want to make a 60cm coil that can detect 2kg gold at 1m or 2!
                          I did not know the 60cm coil needed to shield or no! :confused:
                          Tell me it, please.
                          Thank you.
                            Tell me it, please.
                            Thank you.
                            Do not need shield. It work at low frequency (100Hz) and the object is big. Construct it . Don't afraid.
                            Wishes
                              Wishes
                              Thank you very much Geo
                              • Geo
                                What do you think of the two box metal detectors for me?
