Delta Pulse
  • check
      check
      [ATTACH]27302[/ATTACH]
      thanks
      i use ne556 instead of lm556, i have 80mks and perid of this on ne556-5 is 2.5mks ( not 10ms)
      and i get in ne556-9 350hz but the it is 17mks not 100-500mks
      so ne556 have more DIFFERENCE to lm556 ???
      • no difference. they both are same.
        increase C1 and/or R1 value
        increase C3 and/or R4.
        VERY seems your nominals of componets ARE WRONG and you DO NOT MEASURE ALL COMPONENTS BEFORE SOLDERING
          thanks my delta pulse work but i need to find best adjustment Mr Kt315,for all Tp points .
          my coil is 21m 0.7wire 495mkh.
          • all adjusments will be get automatically. DP was projected for fully dumbs, for a kitchen home worker female. DP has only one (ONE) pot for adjusment - P.P.S.
            tune 120Hz for US standart electrical net and 100Hz for EU standart electrical net, this decreases the interference.
              ok i will set pps on 120 hz.
              • hi dear KT315
                i finish that detector and work very good.
                but i make turkey board , please put it here for me your design (on board and under board, your pcb my means )
                thanks again and best wishes.
                • hi Mohandes, have you P-CAD 2006 installed? I could put a file in it.
                    hi
                    i have P-CAD2002 ,if can not open please put here pdf file( original size of pcb ) and another explain.
                    regards.
                    can i make 1.5m*1.5m coil ( and by telephone cable )??? how i calc the inductance ??
                    • here .PCB file. I cant say it will open in P-CAD 2002 or not...
                      • how i calc the inductance ??
                        you are in course... DVD keeps all diggest of soft and formulas how calc the coil... but again...
                        I can not take from the forum and put back its again... that is very exhausting for me...
                        Sizif's Labour... to bring up the rock at mountain again and again that anyway comes down at earth.
                        so I promise you... everybody will get DVD with all diggest. everybody WHO WANTS.
                        who does not want will be stay out.
                        open Gary Chemelec site... http://chemelec.com/Calculators/Calculators.htm
                        look there A Radial Coil Calculator
                        Does coils like I use on my metal detector
                        input your data....
                          many thanks
                          i will make another
                          hmmm , i think you make difference dp2 , and I hope it is work . ( are you make it and test it ???)
                          about the DVD all banks are boycott so i should going to in EXCHANGE STORE to pay you, i will again try.
                          best wishes
                            hi, it is strangely. version at pic
                            [ATTACH]27286[/ATTACH]
                            Yes thank you Kt315
                            I managed to open it. A true outline
                            I wish you good luck
                            • Originally posted by mohandes View Post
                              hi all
                              i finish dp2
                              please say me the connection lcd to main board
                              this is my lcd that i download it frome turkey
                              http://hipup.ir/do.php?id=871
                              or
                              Hi Mohandes I recommend you to use the other type schema for descrimination
                              https://www.dropbox.com/s/0gum0sw8mlyvt20/PCB.pdf
                              https://www.dropbox.com/s/hb0ghqcxvn...3%BC%C5%9F.pdf
                              https://www.dropbox.com/s/d01ijqzmwc...0%C5%9Fema.pdf
                              https://www.dropbox.com/s/dvfcpozzz9x8hw1/%C5%9Eema.pdf
                              https://www.dropbox.com/sh/1hlyebnlsoyjsex/GDR816sL80
                              • Good evening..
                                I have designed pcb individually all departments separately for experimentation. believe that this is easier for an improvement and research..
                                if desired to publish ??..
