Delta Pulse
  • my deltapulse info
    thanks ivconic,
    I did same coil like you, i wound 30 wind. on 20 cm , o.4mm wire, but not equal performances. i tried a 18cm coil with 40 wind, 0,6 mm ; same depth but very good sensibility and good sound with small coins. If i remember, resistance is about 3,8 ohm for 20 cm coil, i haven't inductance meter but i project to build one...
    5 cents euros : ~15 cm
    50 cents euros : ~20 cm
    2 euros : ~25cm
    • Happy new year !
      my little deltapulse project
      • Happy new year !
        ...verso...
        • Happy new year !
          ... and my previous deltapulse coils... ... because no great depth like ivconic..
          • Happy new year !
            a better quality of my previous deltapulse picture
            • With 20...25 cm coil you must detect a 2Euro coin at 30 cm and a soda can (330ml) at 70..75 cm with good stability. But DP is an excellent low frequency metal detector for large objects. For small coins there are other PI detectors better than DP.
              BTW you made very good pcb's
                thanks géo,
                not far from my home I have several stores of components, I have the choice. I make manufacture the pcb on the Web for a few euros (about 13 euros). I do not do sufficient circuit to buy materiel. it is more economic to make them realize by somebody else. I do not have to test my deltapulse yet on the ground. I have make the tests of detection at home, and there is many metal a little everywhere. Perhaps that I will have better result outside...
                • Delta Pulse
                  Dan129 , Nice Work !!! The Delta Pulse and also photos on dbp-2010 , A good way to start 2007 , Have a Happy New Year Too !!! Eugene
                  • ??? res
                    :confused:
                    DAN129, what is value of this resistor you put on your DP?
                    I can see quite different colors than expected!?
                    regards!
                    • Delta Pulse capacitors
                      Hi Ivconic, Geo or anyone that can help.
                      First of all, happy new year to everyone.
                      I had re-checked mi delta pulse circuit, and all seems to be working, but still no sound.
                      A measure fequency, it running from 400 to 650 hz.
                      A measure EMF, it get strong signal when i raise noise potentiometer.
                      When i disconect the power you can heard a fading and short sound.
                      Some times when you apply power to the unit, you can heard a fast cliking tone that is going down for a couple of seconds, until stops cliking very slowly.
                      For me it seems that the circuit is working, but it has something wrong with capacitors.
                      For example, almost all mi electrolitics capacitors are for 16 volts, specially C27 (220uF, 16 volts) I took a look to the pictures of other DP circuits, and i compared the size with mine, wich looks phisicaly small than the others projects.
                      Sorry, but i not very skilly on electronics.
                      In advance many thanks
                      Nelson
                      I have only a list, wrote by Jean-Charles. do you mean this list?
                      Composant Valeur
                      C1 15nF
                      C2 1nF
                      C3 10nF
                      C4 1,5nF
                      C5 1,5nF
                      C6 1,5nF
                      C7 220µF
                      C8 10µF
                      C9 100nF
                      C10 100nF
                      C11 100nF
                      C12 100µF
                      C13 15pF
                      C14 100nF
                      C15 100nF
                      C16 100nF
                      C17 47pF
                      C18 100nF
                      C19 100nF
                      C20 100nF
                      C21 10µF
                      C22 100nF
                      C23 100nF
                      C24 100nF
                      C25 220nF
                      C26 47nF
                      C27 220µF
                      C28 100nF
                      C29 100µF
                      CI1 LM556
                      CI2 CD4538
                      CI3 CD4538
                      CI4 LF357
                      CI5 TL062
                      CI6 TL062
                      CI7 TL062
                      CI8 NE555
                      CI9 CD4066
                      CI10 CD4066
                      P1_1 47k
                      P2 470k
                      P3 22k
                      P4 22k
                      P5 10k
                      PR1 220k
                      R1 680k
                      R2 6k8
                      R3 47k
                      R4 5k6
                      R5 2k2
                      R6 680
                      R7 15k
                      R8 27k
                      R9 68k
                      R10 100k
                      R11 100k
                      R12 10k
                      R13 10k
                      R14 1k
                      R15 820
                      R16 12k
                      R17 120k
                      R18 120k
                      R19 4k7
                      R20 2k2
                      R21 47k
                      R22 47k
                      R23 4k7
                      R24 4k7
                      R25 4k7
                      R26 4k7
                      R27 4k7
                      R28 56k
                      R29 1M
                      R30 1M
                      R31 5k6
                      R32 330
                      R33 4k7
                      R34 22k
                      R35 5k6
                      R36 56k
                      R37 560
                      R38 10k
                      R39 1k
                      R40 12k
                      R41 6k8
                      R42 22k
                      R43 6k8
                      R44 330
                      R45 39
                      R46 2,2
                      R47 2k2
                      R48 8k2
                      T1 IRF840
                      T2 BC546
                      T3 BC557
                      T4 BC546
                      T5 BC546
                      T6 BC546
                      T7 BC546
                      T8 BC546
                      T9 BC557
                      T10 BC557
                      VD1 1N4148
                      VD2 1N4148
                      VD3 1N4148
                      VD4 1N4148
                      VD5 1N4148
                      VD6 1N4148
                      VD7 1N4148
                      VD8 1N4148
                      VD9 1N4148
                      VD10 1N4148
                      VD11 1N4148
                      VD12 1N4148
                      VD13 1N4148
                      VD14 Zener 8V2
                      VD15 Zener 9V1
                      • fréquence modif.
                        :confused:
                        regards!
                        hi ivconic,
                        I tested increased frequency of the DP by modifying R1 or PR1. With PR1(200k)+R1(680k) you can turn PR1 to have F = approximately 99 to 150 Hz roughly. If one decreases the value of R1, one increases the work frequency of the deltapulse. The problem it is that the coil of detection starts to whirr. I dont' remenber the value i soldered, i'am at office. bye
                        • too high frequency
                          Nelson
                          verify these values of component. while turning PR1 you should vary between 90 and 150 Hz. Perhaps the problem does not come from there, but starts already with this checking. with such a raised frequency, the coil should whirr
                          PR1 = 200 k or 220 k
                          R1 = 680 k
                          C1 = 15 nf
                          R2 = 6,8 k
                          NE556, i don't use LM556
                          • R1=???
                            :confused:
                            "With PR1(200k)+R1(680k)..."
                            I know this. On your picture R1 does not look as 680K.....not even close?
                            Not even Kohms....but in ohms??? Or picture is not clear enough....blur?
                            Anyway, regards!
                            • One more question about making PSII Coil
                              Thanks Ivconic for advice on building PSII universal coil,
                              I found this wire quite cheap (US $0.50/foot). It is 12 conductor wire. Do you think it will be suitable?
                              One more question: what to do with the aluminium shield wire? Is it to be connected to one of the terminal wires?
                              Thank you again,
                              Bob
                              • Yes!
                                Yes! To ground. In this case GND is +pole....althought there is digital ground on pcb....i am wandering about it? I never used f.cage,since my previous devices worked on low freq. and i made only large coils so far...
                                It is good question! Where to connect shield??? On +pole or to digital ground?
                                Any ideas?
                                Geo?
                                :confused:
