Delta Pulse
  • Originally posted by Hannu View Post
    Jose, in your calculation bundle diameter is 70mm. Is this correct?
    Here is calculation with d=0.5mm wire and 7mm bundle diameter. [ATTACH]32013[/ATTACH]
    hi can you put this program here.
    • Originally posted by mohandes View Post
      http://www.miscel.dk/MiscEl/MiscEl.zip
      • calcoil program I use. needs to install.
        http://www.avral.ru/b542b772b87b797e0d1b433c47566f6f
        • making fast basket coil for test
            I apologize.
            It should be 7mm. Not 70mm.
            The inductance for "Bundle diameter" 7 mm, is 1008 uH.
            José
            • Comment
                KT315 , can give more data for this coil. diameter and winding.
                  hi my dear friend jose
                  i use cate6 cable and get best result .
                  i make new coil and put here for share all . i think if have 400mkh to 500 mkh is good and best R between 2.5 to 4 ohm.
                  about parallel best is 470 ohm to 500 ohm.
                  best wishes for all .
                  Hello Mohandes
                  I welcome the smooth running of your coil.
                  It's good to experiment a little.
                  • middle diameter of the coil is 195mm, calcoil gives me 26 turn for 'several layers' coil, so I only figure on this data. will make more and measure what ll get.
                    wire diameter is 0,5mm.
                    • delta pulse test
                      http://s5.picofile.com/file/81600843...07047.mp4.html
                      • Originally posted by star View Post
                        good but not like me. what size of your coil?i get by 28cm coil this result.
                        250R coin in 40 to 45 cm.
                        (تن ماهی ) tonafish in 55 to 58 cm and....
                        • hi kt315 and anybody
                          any body work by 110*110 cm in wild land or soil or mountains .
                          i want understand have good stability and good work in real ????
                          i just test in air.
                          • Comment
                              coil 40 cm
                              coin 45 cm
                              tonafish 90 cm
                              • ahhhhhhhhhhh
                                in my country have not graphite spray. so i should use Al foil .
                                regards.
