Delta Pulse
  • Pa jel imas cime da se hvalis ?
    • Ne
      • Originally posted by rankx0 View Post
        OK, I've messaged ivconic. Thanks! But you could also answer about maximum current through diode? Is 11A enough?
        if you did read all the thread this mod with the diode is not mine. i only released that in my board, there was a free place. LOL.
        • Originally posted by gaby_sult View Post
          Here's where you can see the catalog features everything you want. http://www.alldatasheet.com/
          I tried STTH1210 but honestly coil 20cm decreased sensitivity to small objects, so try with or without diode and see the difference.
          Read this :
          http://www.geotech1.com/forums/showt...704#post225704
          thats true. for big PULSE WIDTH maybe it has a value, but for low one not. people are so idiotically conservative,
          that instead to try find a mosfet with 1200v they are wasting a time on finding of the diode.
          all only ask what diode is best.
            Ne
            Come on guys, make your posts in English.
            You should know the rules by now -> Basic Rules of the Forums
            • come on people. all serbians are here in one band LOL
              • so hard to find up??
                http://www.ebay.com/sch/i.html?_from...+1200V&_sop=15
                • Actually no, but locally I can buy this: 2SK1358, 900V, 9A, 150W, 1,4R. However I am pretty sure that DSEI12-12A as a diode will work just fine And perhaps I don't need it at all, since we plan to use only small coil (this is a gift for my kids).
                  • try a HV diode from any CRT tvsets/vga/svga trash boards. it stays on a radiator near HOT transistor.
                    • It is no bad question, but the issue is not addressed ranx0 than Toros ,He is me provoked to another topic and you have not responded thank you !
                      • Orbit, if you have a dispute with me write personal messages. You do not have to write strange messages in the thread Delta pulse.
                          damping resistor is like a tuning matter. look at this illustration.
                          [ATTACH]24418[/ATTACH]
                          At which point you measure this? I tried at pin 6 of LF357, but I have nothing similar there? I have a Surf PI and I successfully measured this at output of NE5534, and then set damping resistor, but I am not sure where is this point on Delta Pulse? Could you please help?
                          • surf and bara are P-channel mosfet driver based. DP is N-channel mosfet. pic is different mirrored.
                              I know that, it is pretty obvious, so I didn't ask you about mirrored picture, I have asked AT WHICH POINT on DP to measure that?
                              • OK, I found that I shall measure it at TP3, it was in this post: http://www.geotech1.com/forums/showt...9943#post89943.
                                Also, I found out that my IRF740 was not working, so when I replaced it, everything runs!
