Delta Pulse
  • Comment
    • 1. Look for a short circuit between the paths on the board.
      2. Look for a faulty element that can short-circuit.
      The two LEDs indicate the presence of power and the voltage drops below the allowable minimum.
      The second diode lights when the voltage drops. With a correct power supply, it can only light up when the circuit board is short-circuited.
      • lots of closed lines on your board on bottom. i see only problems with your layout.
        • thank you for all. do you think i'm using a wrong pcb?please correct me
          • Originally posted by mazari View Post
            Take a look here for correct PCB:
            • many thanks for your help
              • hi for all.this pcb differs from the pcb I'm working on.please can you give me part list compponents.
                • pcb I'm working on now
Name:	delta pulse components values all modifications.jpg
                    • thank you very much for your help.
                      • hi for all.
                        I have just finished to build the Delta Pulse2 unfortunately it did't work there's no sound i have only green led lighted .all componenets are tested .please can any one help me to find what would be the problem ?thank you in advance.
                        • please take a look at this video
                          delta.flv
                          • new board rev3.1
                            top+top silk
                            http://storage1.static.itmages.ru/i/...783de9f9bf.jpg
                            • many thanks mr k315.but i haven't pcb for this board. please tell me what is wrong in my pcb? thank you again
                              • your pcb is turkish layout. you have to ask turkish just cause this type of board is unknown for me.
                                check signals in all test points, for first step.
