Delta Pulse
  • #61
    Hi All,
    Hİ Kt315
    is it possible for you to give components lay out list.Like aban did for xr71p
    I want to build your 400khz pcb.
    and if you can put picture for connections It would be better for everybody.
    may be step by step building pictures?
    thanks
    have a nice day
    • #62
      DELTA PULS in Sprint Layout format. pls check it with PCB image you have of.
      • #63
        Hi Kt315
        thanks for your answer first.
        But I could not open your attecment.
        to see which program do I have to use?
        you can also use my mail
        okantex2000@yahoo.com
        if needs.
        • #64
          SPRINT LAYOUT 4.0. , yours
          • #65
            thanks kt315
            but I wanted to mean something like abans component list.
            in abans lay out list there are some unwritten transistors and unnamed components for new starting builders.
            and I thought may be you can give full components layout list for easy build study.
            in your file, positions of components are okay.but what are their names(numbers,codes)
            I can not decide which component to put where
            • #66
              Read from schematics?
              http://thunting.com/geotech/forums/a...entid=75&stc=1
              I constructed mine from schematics.
              • #67
                Hi Lake
                thanks for your offer first
                but as gemini build it wrong through the sheet ,I can also build it wrong.
                I build two detector before and non worked.
                if someone helps with pictures we could build for us, too.
                for example Geo's pcb layout is much better.because it showscomponents with numbers in schematic.that is okay but still I can not find C30,C31 in it.
                if somebody puts pictures of finished pcb .and connections of outer parts ,it will be good for all.
                thanks all
                • #68
                  you could be turn on Search engine in the forum and to see there are much about DP. the people likes to double one subject in much lines... why - I do not know (((
                  for example
                  https://www.geotech1.com/thuntings/s...ighlight=delta
                  yours
                  • #69
                    Hi kt315
                    Thanks.I know that pages.also I have them in my PC.
                    but my problem is that I can not identify all components.
                    at first I wanted to build xr71 but as you can see in the link you gave.there are some components not written openly.like some transistors just called NPN but what are they.I looked at geo's schematic .there I saw two types BC214 and BC284 .which one is which one?
                    this is my problem.
                    if you can enlarge the picture of components and add absent ones in paint .
                    it would be easy to build.
                    And another problem is that in delta schamatic there is C30 ,C31 ..but in pcb layouts there is no C30,C31 ..
                    delta is commercial and can create problems for our site.but you can help for xr71 .nowadays no body produces it as commercial I think.
                    can you control and correct all components for us please
                    thanks
                    have a nice day
                    • #70
                      I have only a list, wrote by Jean-Charles. do you mean this list?
                      Composant Valeur
                      C1 15nF
                      C2 1nF
                      C3 10nF
                      C4 1,5nF
                      C5 1,5nF
                      C6 1,5nF
                      C7 220µF
                      C8 10µF
                      C9 100nF
                      C10 100nF
                      C11 100nF
                      C12 100µF
                      C13 15pF
                      C14 100nF
                      C15 100nF
                      C16 100nF
                      C17 47pF
                      C18 100nF
                      C19 100nF
                      C20 100nF
                      C21 10µF
                      C22 100nF
                      C23 100nF
                      C24 100nF
                      C25 220nF
                      C26 47nF
                      C27 220µF
                      C28 100nF
                      C29 100µF
                      CI1 LM556
                      CI2 CD4538
                      CI3 CD4538
                      CI4 LF357
                      CI5 TL062
                      CI6 TL062
                      CI7 TL062
                      CI8 NE555
                      CI9 CD4066
                      CI10 CD4066
                      P1_1 47k
                      P2 470k
                      P3 22k
                      P4 22k
                      P5 10k
                      PR1 220k
                      R1 680k
                      R2 6k8
                      R3 47k
                      R4 5k6
                      R5 2k2
                      R6 680
                      R7 15k
                      R8 27k
                      R9 68k
                      R10 100k
                      R11 100k
                      R12 10k
                      R13 10k
                      R14 1k
                      R15 820
                      R16 12k
                      R17 120k
                      R18 120k
                      R19 4k7
                      R20 2k2
                      R21 47k
                      R22 47k
                      R23 4k7
                      R24 4k7
                      R25 4k7
                      R26 4k7
                      R27 4k7
                      R28 56k
                      R29 1M
                      R30 1M
                      R31 5k6
                      R32 330
                      R33 4k7
                      R34 22k
                      R35 5k6
                      R36 56k
                      R37 560
                      R38 10k
                      R39 1k
                      R40 12k
                      R41 6k8
                      R42 22k
                      R43 6k8
                      R44 330
                      R45 39
                      R46 2,2
                      R47 2k2
                      R48 8k2
                      T1 IRF840
                      T2 BC546
                      T3 BC557
                      T4 BC546
                      T5 BC546
                      T6 BC546
                      T7 BC546
                      T8 BC546
                      T9 BC557
                      T10 BC557
                      VD1 1N4148
                      VD2 1N4148
                      VD3 1N4148
                      VD4 1N4148
                      VD5 1N4148
                      VD6 1N4148
                      VD7 1N4148
                      VD8 1N4148
                      VD9 1N4148
                      VD10 1N4148
                      VD11 1N4148
                      VD12 1N4148
                      VD13 1N4148
                      VD14 Zener 8V2
                      VD15 Zener 9V1
                      • #71
                        thanks Kt315
                        I looked at schematics.
                        this list is for delta.
                        I still have questions.
                        in schematic there are components like vd16,vd17,c30,c31
                        where will we use them.
                        will not we need them?
                        this list just gives components on pcb ,am I right?
                        can you give me full elements list that I have to buy from electronic store
                        including potensiometers,current meter scala,on/off button and others
                        • #72
                          what is the value of Tr1?
                          are PR1 and Tr1 both trimmer pot?
                          I do not know what PR means
                          • #73
                            delta
                            Full doc. Shematic Delta PI
                            http://www.treiti.times.lv/shem/deltapi_v1_treiti.zip
                            Soft Sprint Layot v4
                            Treiti
                            • #74
                              respondanle a okantex el tiene inquietudes y necesita su opinion, acuerdense de cuando ustedes tambien necesitaban de la dirigencia de otros, creo que okantex empieza y necesita su supervision, y haganlo muy detalladamente y claramente, claro esta los que saben, si yo supiera le diria, pero tambien soy neofito en esto, claro me las ingenio para entender, pero okantex esta metido en un proyecto que para el es muy desmesurado quizas de acuerdo a sus animos
                              ok help to okantex
                              detectorista detectoman
                              • #75
                                Hi Detectoman
                                I see tha t you wnt to help me
                                THANKS A LOT
                                but I can not understand your language.
