Delta Pulse
  • pcb size
    Originally posted by erolunall View Post
    Hello
    I attached 1.zip printable Pcb for delta pulse .
    Best Wishes
    Erol Ünal
    hi erolunall thank's actually i need size of pcb in milli meter i mean how many squer mm lenth and hight...rajesh
    • Hello friends.
      I read your comment and understand to your metal detector. I think your metal detector little bit too short. You detect a coke can be increasing. you will more research to this equipment and you may be improvement it...
      • Hello everyone
        Thanks Ivconic and kt315 by answer questions.
        Sincerely
        • Hi all
          I used 1mm wire for 1*1 coil 18 turns ,but it is has poor sensitivity
          please guide me.
          I used it.
          Thanks.
          Iman Boroumand.
          • Originally posted by Belief View Post
            Hi all
            please guide me.
            I used it.
            Thanks.
            Iman Boroumand.
            Hello Belief
            Try reducing R5, 680 ohm (page 33, post 823) to 400 ohms or less
            Sincerely Jose
              Hi all
              please guide me.
              I used it.
              Thanks.
              Iman Boroumand.
              'if anything does not go via a head... it will go via your hands without doubt!'
              try again. take FAT diameter in good isolation. i used 2,5 mm multifilamentary-twisted-stranded wire what I could be find around...
              nobody here suggested to use tiny diameter for hypercoil
              • Hi All
                in original delta pulse, sniffer-xr71 which one of tl062 or tl072 or tl082 is used ? and whch one is better?
                Thanks...
                • my delta pulse has low sensitivity to gold & copper , why ?
                  please give me an advice ..
                  Thanks...
                    Thanks...
                    Do something with sampling-time.
                    • Hello Belief
                      http://md4u.ru/files/XR-71.pdf used tl062 and tl072
                      Erol
                        Hi, Belief
                        There are too much turns, I think.
                        I made frame-coil 1m*1m for my PI, by 12 turns of wire 2,5 sq.mm.
                        Regards.
                          Hi All
                          Thanks...
                          any of them will be OK. better in order - 082 than 072 than 062, so 082 is best in your list.
                            Hi WM6
                            what do you mean "sampling-time" ?
                            • Hi kt315
                              Thanks...
                                Hi kt315
                                Thanks...
                                in theory PI mashine is really more sensitive to ferrous metals, not to gold. it is normal. let gurus in this forum to give you more detailed report on this matter... if you so need in the theory and patents... mine english is not so applicable for longest extensive structured cool&hard classified answers you could be hope. i am more a practician than theorist...
                                good luck
