I looked at schematics.
this list is for delta.
I still have questions.
in schematic there are components like vd16,vd17,c30,c31
where will we use them.
will not we need them?
this list just gives components on pcb ,am I right?
can you give me full elements list that I have to buy from electronic store
including potensiometers,current meter scala,on/off button and others
Hi.
VD16, VD17 are leds. One for power on and the other for low battery. C30 and C31 are electrolytics capacitors. You can use only one (no c31).
English version:
Detectorman... It is better if you write in english and also in spanish. The gringos don't understand what you say. If you write in english and spanish, then all will understand. You speak good enough english for us to understand.
geo: one question for you., maistro, what is the mejor detector diagram? delta pi?
and the most little diagram also effective for build
geo una pregunta para ti, maistro de los detectores, jejeje un abrazote, ahora pregunto, cual es el mejor diagrama facil y conseguible en la red, es acaso el delta pi, o hay otro? y te pregunto si existe un sencillo diagrama ruso o ingles, o del que sea ,que siendo pequeño y facil de construir sea muy efectivo? cual viene siendo?
I did not mean TR1
there are test point called TR1, TR2 ,TR3 .....but Tr1 is different.it has connection to VD9 look at your post (component layout) in page 2 of this thread.
in xr71 there are trimer-pot 250k and trim-1K
in delta there are PR and this Tr1
but value is not given
thanks to everybody
nos vemos brother
detectorista detectoman
Sorry but i dont understand what you mean. Maybe someone can translate from spanish.
I did not mean TR1
thanks to everybody
Hi okantex.
VD9 is D9 and TR1 is the transistor T1 (IRF740).
Pr1 is a trimmer 200-250K. No need other trimmer. The trimmers and resistors with xx value no needing. We can use them for fine reg with the other potensiometers. So we must experiment with the values.
Regards.
hi geo , my question is: what is the best diagram in little size, of you experience ,on pi detectors ,avaliable in internet for i build , i am one begginer not expert on complex pcb
best regards
detectorista
Hi detectoman.
You can build the Barracuda PI detector. It is one of the best detectors, simple and with common components.
For Okantex.
D7 (1N4001) is not important.
It needing to protect the detector from reverse supply.
according to your layout picture in page two ,
what is the exact size of that lay out.what size board do I have to buy for this pcb?
And Do I have to use sockets for TL entegres(IC) as in your XR71 which eric sent you.would they get harm while mounting because of heat.
thanks
... and fix it with epoxy glue it is very important NOT to use silicon compend because it generate a corrosive vapor bad for your connexion.
What is the purpose for epoxy glue?
Just to keep coil in fixed position/inductance etc?
I wonder can the maximum range be reached in testbench before the coil is glued?
What about the coil winding tightness?
thanks brother geo for these diagram gime to me, is the barracude deeper? is stable? i think the ics of barracude ,are very hard avaliable , ok geo you read the panel faraday shield, of coils, i put one information well for you of my invest
ok best regards geo
till tomorrow
detectoman
other diagram is the mini plus detecor ,you tink these is best?
