Delta Pulse
  • can you help me about the list of component for lcd
    • no szucs_g. p6 and p7 that i show on pcb and schematic use for lcd
      I attached some file for that lcd.I have delta pulse dircriminator lcd circuit too .i can upload here if you want
      freedan3d
      • thank you for your reply but I need the list of component for this lcd
        • Hi samifathi
          Your pcb is delta pulse discriminator lcd circuit and i have its all data
          I attach a rar file for you and other users
          enjoy it
          freedan3d
          • thank you
            what is the value of resistor RX and capacitor 1000uF 6.3V or 1000uF 16V
            sincerly
            • That resistor is for lcd backlight contrast .I use a Potentiometer for it
              and i used 1000uf 10v for that it is not important
              • thank you so much
                • Hello Freedan3d
                  Thanks for posting the file: "discriminator.rar".
                  It is complete and functional?, Or is it a demo?
                  thanks
                  Jose
                  • Delta pulse lcd
                    Will this LCD work on any delta pulse version?
                    • Sorry error
                      • Question about connector
                        What are the correspondence points between main PCB and LCD PCB?
                        • Hi all..Pretty new on this forum, but reading it daily. Great to see you all over the world busy with this project.
                          I'm following this for some time, and decided to follow you on your work, to make a great MD. Only problem i have right now is that my ne556 is getting hot, while without irf740.
                          strugling here to get this problem solved. Circuit is checked several times. I try to catch this project up and hopefully my problem is soon solved.
                          Maybe any idea's around? Ow, i replaced vd8 and vd9..no difference
                          It's a while ago, i did't electronics..(20years+)
                          Thx.
                          • Originally posted by Oorlam View Post
                            Thx.
                            Check if a short circuit between the outputs of 556 and GND.If is gone, replaced with other 556th
                            • I forgot
                              I forgot to say that we should first check whether a short circuit between the output 556 (5 i9), then remove NE556Sorry for my bad English.
                              • Originally posted by VUJO View Post
                                Nice, thx for your speedy reaction .
                                I allrdy chked it. Found a mistake in PR1 221 instead of 203..i placed now 223, because i have no others here around now. Funny part is, when not on and wait some short time,and switch on.. it works, but after some small time (1 minute)the power consumtion is increased with factor 10. (50Mamp)..Seems there's a bad condensor in the circuit. I'm testing it without irf740..
                                My English is like yours, but it works for both of us
