Hi pigeon
This question Repeater[And that hate him] - should keep in mind that the length of detection[Within] equals once or one and a half times the length of the diameter of coil and you will not get the best distance from this only by increasing the diameter.[And grow Resistance parallel to coil].,Taking into account the size of the target proportion to diameter of coil.Of course, a small target with a small coil and vice versa.
-u 50cm coil is good .
-You did not mention the size of the target???
-detection in air Differs from inside the earth.
-This improvement to some extent and stopped at because it depends on many factors, including the design itself.
-try to make 1x1m with Same specifications ohm , uh,,Possible that up to ask!!!!!
best time
j.
best time
j.
